Pictures from 2015 NXT West
Results 1 to 10 of 13
Thread: Pictures from 2015 NXT West
    21,404
    1139
    For four days in late June the NXT Institute took over the Meguiar's Training Center and hosted some of the most talented professional detailers in the US and Canada, and from as far as Trinidad, Denmark and The Netherlands. In conjunction with Kevin Brown of buffdaddy.com we held two days of "standard" NXT training and two days of "advanced" NXT training. Both courses consisted of advanced wet sanding and buffing techniques, with the advanced course focusing more time to the actual hands on aspect - many hours each day, in fact - as well as dealing with more advanced aspects of sanding and polishing very small areas or in very tight confines.
    While the majority of attendees had several years of experience under their belts already, a few were quite new to detailing, or at least to wet sanding. To watch the level of openness, sharing, camaraderie, enthusiasm and passion among everyone present, regardless of skill set, was inspiring in itself. Lead instructors for the program were Kevin Brown, Meguiar's own Jason Rose, and myself. Assisting us during the hands on sessions were Greg Nichols of Reflections Detailing in Utah, Christopher Brown of OCDcarcare.com, Joe Fernandez of Superior Shine and Derek Bemiss of Detailwerks. During the classroom sessions these guys would totally reset the garage, cleaning up the mess from the previous session and setting the work stations with the proper tools, liquids, pads, etc for the next step of the process. Volunteering to help with this critical task (including regularly doing the laundry!!) were Bob Bartel and Andy Wong. Without the help of this group of guys, who did simply out of their passion for detailing, this would have been a very different experience. I know I speak for both Kevin and Jason when I say this team was invaluable throughout the four days, and we can't thank you guys enough!!!
    Wednesday was spent getting the work stations set up; a huge task all by itself!!
    Pick your polish (or compound, as the case may be)....
    Pick your pad...
    Pick your polisher.
    With a maximum of 20 students per day being taught by 3 primary instructors and 3 or 4 assistants (depending on the day), the student to instructor ratio was such that everyone got plenty of one-on-one assistance.
    Kevin shows off an edging technique with the MT300
    Below is an interesting comparison of two sanding techniques: texture leveling versus texture matching. With texture leveling the intent is to do just that - level the texture and remove orange peel. With texture matching the goal is to remove defects from an area of the paint without causing the repaired area to now look different from the rest of the vehicle. These two processes are accomplished with similar, but strikingly different approaches. Leveling makes use of hand block sanding, or DA sanding with a sanding disc rather than a finishing disc. Matching involves the use of only a DA finishing disc paired with a foam interface pad. In the image below the panel had been taped off and one side was hand sanded with 1000 grit and then 3000 grit sand paper. This did an excellent job of leveling the heavy texture present in the test panel. The tape was then removed and the entire area was sanded using only a 3000 grit finishing disc on a DA sander. The area you see here has been sanded by not yet buffed out. The right side shows the flatter reflection while the left side still shows all the orange peel. Notice, however, that in the orange peel section there are no shiny areas which would indicate that the bottoms of the orange peel "waves" had not been touched. The entire contour of the peel has been sanded, potentially removing defects while maintaining uniform texture throughout the vehicle.
    Working with a 1" sanding disc on a small pneumatic DA sander.
    The two advanced days, Friday and Sunday, saw the garage reset to accommodate cars rather than hoods and panels. Yep, this got real in a hurry!
    One technique we discussed was "edge work" versus "panel work". Sanding in the middle of a large panel is pretty straightforward, but working the edges properly takes a bit more patience, skill, time and potentially some specialized tools. Here, just the panel has been sanded. While our preference is to take care of the edge work first as it gives you a visible safety zone around the perimeter when tackling the main panel, it's not the end of the world if you do it the other way around.
    We normally recommend keeping the pad as flat as possible to the paint, but sometimes you just gotta do what you gotta do. Using a 7" wool pad to handle edge work while removing sanding marks means you'll sometimes be using some serious angle of attack. Will this create a buffer swirl? Most likely, yes, at least to some degree. But that's easy enough to remove with a secondary polishing step.
    Another specific approach that we discussed was the use of 3000 grit damp sanding for the removal of more severe defects, rather than just hammering away with a buffer and an aggressive pad/liquid combo. The latter can introduce a lot of heat into the paint, and modern paint simply does not like heat. Using a 3000 grit finishing disc and water introduces no heat, yields a very controlled and uniform sanding mark, and it extremely easy to buff out without stressing the paint. In many situations, as counter intuitive as it may sound, sanding and then buffing instead of simply buffing really is the less invasive and safer approach.
    On this rental car there was a long and fairly deep scratch in the trunk lid. Jason talked about the process and then got to work on the defect.
    A little 3000 grit on a 3" DA sander.
    Immediately after sanding... yes, that white residue is indeed clear coat.
    Using the exact same tool with which we sanded the area, we switch to a microfiber cutting disc and M105.
    In just a couple quick passes across the paint the sanding marks were gone, and with them so was the original scratch.
    At certain angles, with the right light, you could still find a trace of the deepest part of the scratch, but it was impossible to capture with the camera. The remnant in question is right above the fingertip in this shot. Seriously, it's there if you have just the right conditions to find it. Sometimes a defect is just too deep to level safely. But if we can, very quickly and with almost zero heat, take that scratch to this using just two very quick steps, we don't think any car owner would complain.
    One again, an enormous thank you to everyone involved - from the assistant instructors to the volunteer clean up crew to the attendees themselves - for making 2015 NXT West such a huge success. We hope to see you on the East Coast in September for 2015 NXT East!!
    Sep 2005
    Sydney, Australia
    4,312
    66
    Re: Pictures from 2015 NXT West
    Wow, that looks awesome.
    If only I could attend, I'd be like a kid in a candy store! All those products, tools and detailing gurus all in the one place...
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,892
    67
    Great stuff indeed. I can't wait for NxT Institute East Coast
    Sep 2008
    Sydney, Australia
    1,354
    26
    Fantastic event indeed!
    Davey, maybe we should plan a little US holiday that just happens to coincide with the next one of these!
    Sep 2005
    Sydney, Australia
    4,312
    66
    Quote Originally Posted by Selectchoice View Post
    Sure thing!
    While we're there, we can also do: SEMA, Detail Fest, Barret Jackson, Carlisle x 3, Pebble Beach Concours d'Elegance etc etc...
    Sep 2008
    Sydney, Australia
    1,354
    26
    Sure thing!
    Perfect itinerary! Book the tickets today?
    Registered Member juliom2's Avatar
    Aug 2010
    Puerto Rico
    274
    All bases covered. Awesome hands on.
    I'll would like to get more into detail with the advance wet sanding techniques.
    Brought you by the All star Team @ Meguiars.
    Great tools too. Even a little rotary that has yet to be promoted in the us was part of the arsenal.
    Nice!!!!
    21,404
    1139
    Sure thing!
    So, an entire year in the US then, right guys?
    Hey, you wouldn't be the first from Australia to attend NXT as we had a couple of Aussies here last year. We'd love to have both of you attend and, quite frankly, I'd love to meet both of you guys anyway!
    Sep 2005
    Sydney, Australia
    4,312
    66
    Likewise Mike!
    Perhaps Meguiars can fly us over? You know, in the interests of international PR...
    Sep 2008
    Sydney, Australia
    1,354
    26
    This trip sounds like a great MOL write up in the making...
  1. NXT Institute High Level Training - East & West Coast Editions for 2015
    By Michael Stoops in forum Company & Forum Announcements
    Last Post: Mar 16th, 2016, 11:27 AM
  2. Robie Reid NXT 2015 west, finally made a account!
    By RobRunner94 in forum Introduce Yourself - New Members
    Last Post: Jun 27th, 2015, 05:12 PM
  3. Pictures from May 9, 2015 Advanced Class
    By Michael Stoops in forum Pictures from Meguiar's Training Garage - Intro to Wet Sanding & Rotary Polishing Classes
    Last Post: May 13th, 2015, 11:09 AM
  4. Pictures from Barrett-Jackson, West Palm Beach 2013
    By Michael Stoops in forum The Break Room
    Last Post: Apr 8th, 2013, 10:15 AM
  5. Pictures from Barrett-Jackson West Palm Beach 2012
    Last Post: Apr 7th, 2012, 02:21 PM
