Longevity of Ultimate Past Wax - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Longevity of Ultimate Past Wax
  1. #11
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,538
    64
    Re: Longevity of Ultimate Past Wax
    Search using ultimate quick wax as a drying aid.
  2. #12
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    16
    Quote Originally Posted by eagleguy007 View Post
    Don't have the time for daily detailing, hence the reason for my question.
    You don't have 10 minutes to spare to touch up a car as needed between full washings, etc? Waxes, sealants, or coatings will not keep the car(s) clean, no matter how long they might last. If you want a daily clean look, you have to daily detail, but if you want your protection to last in the hot, wet South, trust me, you need to be boosting it regularly. That was my point, in that it only takes minutes with UWWA, for example, or to QW after a wash. The daily part is not the work you seem to think it is, but it's the key to avoiding lots of too-frequent washing and correcting, which is lots of work.
    First Correction | Gallery
  3. #13
    Jun 2015
    Clermont, Fl
    22
    5
    Used the Finish Kare 1000P (from the other Meguiar) on a 2015 Gray Toyota Venza. Goes on and comes off easy like Meguiars Ultimate Paste Wax (UPW) when put on thin. Gives a similar finish to a wet candy like Meguiars NXT which I like for my 71 Buick. Much more slick than UPW. As far as longevity time will tell.
    A day later I used the 1000P on my 2012 Camry. Put it on a little thicker and found it a little harder to remove. Same results as the Venza. Neither vehicle was clayed as quite frankly I was too lazy. If I had some easy on off polish on hand I may have tried doing that first but I am always concerned about compatibility issues. Tried the Meguiars Ultimate Polish once and hated it. Now we wait and see! According to my records I only got 3 months out of the Meguiars UPW this time round here in Florida before it looked like it was time for a refresh.
  4. #14
    Jul 2013
    Lawndale, CA
    41
    5,538
    64
    I just re read your last post. So you have not been claying prior to applying UPW? Claying helps a sealant bond to the paint and with longevity.
    I suspect you may have the same issue with finish kare.
    What was your issue with ultimate polish? It always comes down to technique and proper use.
  5. #15
    Jun 2015
    Clermont, Fl
    22
    5
    I am not looking to dwell on whether to clay or not because I am not.
    The ultimate polish for me never sets up right.
    Both vehicles are as new and for me the UPW just does not last as long as I would like during the hot summers here in FL.
    For now lets just see how the Finish Care holds up compared to UPW under the same application and conditions.
  6. #16
    Jul 2013
    Lawndale, CA
    41
    5,538
    64
    Then all I can say is good luck.
  7. #17
    Feb 2013
    Carolinas
    842
    16
    eagleguy, it sounds like you may want more correction result than is really likely without a lot of work. I think we can all understand that. The problem is, it's just going to be a lot of work
    It also sounds like you're expecting a wax/sealant to do more than it can do. It's just there to protect the paint, and to protect the claying, compounding and polishing work done to the paint, and give a final "cast" or "look" to the finish. It is not really the correction itself, IMO.
    Much of what we're talking about above is the fact that waxes and sealants will be destroyed in the Sun, heat, humidity, rain, washing, and so forth. What might last for months in a cool, dry region won't last days in a hot, humid, rainy region. Yet, maintenance can be fun and easy on a daily basis. Still, getting a good correction is just going to take as long as it takes.
    Clay: Sure, you can skip claying IF the surface is already baby smooth. If not, it is well worth those long hours to do a full clay job. You may not have to clay like that again for a long time (I think it's been about 2 years, for me, due to frequent DA machine polishing).
    Compound: You haven't talked about this, but it's often essential for getting the surface defect-free. Sometimes compounding can take the place of polishing, and vice-versa. Compound is to be wiped off immediately. Compounding can take far longer than claying with hard paint, and due to maintenance, may not need to be done again for a year or so.
    Polish: Apply polish and wipe it off right then. Do not let it "set up". If it's just the next month or two after you've done all this, you probably don't have to polish again and can just re-wax, because if you've done all the daily maintenance right, those oils are still there, basically. However, after many months, it may be time for another polish.
    Sealant/Wax: The weather where you are, and having to clean the car, will destroy the wax or sealant or coating faster than you want, and faster than the wild claims made on websites. As that happens, the polish underneath begins to weather away, swirls build up, etc. After claying and/or polishing, any wax or sealant with a decent brand name on it will work great, but has to be maintained. A simple re-waxing can be a one-step replacement of the correction sealant/wax, without having to do all the other correction steps again.
    Regular Maintenance: Now it's corrected, you get to relax and enjoy doing small things from day-to-day or once a week or whatever to keep things nice, and there are a lot of threads here on various washing and detailing tricks. You can stay in maintenance mode like this for weeks, months, maybe longer, but again, it depends GREATLY on region, season, weather, heat, sunlight, washings, driving, etc.
    Hope all that helps you
  8. #18
    Cadillac enthusiast Eldorado2k's Avatar
    Jan 2014
    Los Angeles, Ca
    41
    1,257
    20
    Are you applying the products by hand or with a polisher? I've found that with Ultimate Polish it's usually a matter of not working it in long enough, or working it too long.. Different paint and also weather conditions can greatly affect the results. I recall having trouble removing it once, but as soon as I changed my technique to a longer buffing cycle it wiped off effortlessly.
    Also, if you're interested in wax longevity, you might want to try a different approach and give Ultimate Wash & Wax Anywhere a try and see if you like it.. Instead of dragging out the bucket & hose on the weekend you could take a few minutes and do a waterless wash every 3-4 days. Not only will you save yourself the chore of having to spend over an hour washing your car once a week, you'll also wind up with continuous wax protection non stop. Problem solved!
  9. #19
    Sep 2006
    9
    14
    I'm conducting my own little experiment right now.
    I've been using the Meguiar's Ultimate liquid version on my car and it generally lasts about a month of daily driving... but that varies on weather. (if it's really hot or raining it's less)
    I actually waxed my mother's car with it expecting it to last the same amount of time and I was sorely disappointed.
    Her car sits outside all the time and it only lasted about two weeks before most if not all of the beading was gone.
    So I ordered some Collinite as it's supposed to last a very long time, but she left before it arrived and I couldn't put it on her car.
    Now I've got half of my car waxed with Collinite, and the other half waxed with the Ultimate.
    I'll be interested to see if the longevity of Collinite lives up to the press.
  10. #20
    Jun 2015
    Clermont, Fl
    22
    5
    Been using Finish Kare 1000 for awhile now as well as Meguiars. Under the same conditions both leave the same finish but the 1000 last twice as long as the Meguiars.
  1. what I've been up to for the past year
    By 03mach1 in forum The Break Room
    Last Post: Feb 25th, 2015, 08:45 PM
  2. Pad Longevity??
    By JWMotorCars in forum Detailing 101
    Last Post: Jan 12th, 2012, 12:47 PM
  3. The past
    By LARRYKETTER in forum The Break Room
    Last Post: Mar 11th, 2009, 06:47 AM
  4. colorx longevity?
    By refurbish in forum Detailing 101
    Last Post: Apr 7th, 2005, 09:24 AM
  5. Blast from the past
    By perry in forum The Break Room
    Last Post: Sep 15th, 2004, 06:40 PM
