2002 Camaro SS Coated
Results 1 to 10 of 11
Thread: 2002 Camaro SS Coated
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,642
    66
    Well this is my personal car. Before I go on to the photos I would like to give a little background story about this car.
    I am technically the third owner. The first owner was a car collector who had this car in his personal collection. He passed away and the second owner picked it up at a car auction and then I purchased it.
    When I purchased it, the odometer read 3,000 miles. I could not pass the deal and low mileage. I have had it for about 10 years and it's currently sitting at 14,XXX miles. This is the garage queen as they say.
    I've made some changes throughout the years. It has the full hotchkis suspension (sway bars, lowering springs, trailing arms, front strut bar), koni single adjustable shocks, 35th anniversary wheels and an original rear center lip with a Magnaflow cat back exhaust that I modified to be center mount. I only have an intake, exhaust and a tune. I don't want to go all out crazy with the engine mods. This is as far as I am going with those.
    It's been about a year and half since I last did any sort of paint correction/polishing. Since it sits in the garage a lot more the paint stays clean and LSP just lasts. A year and a half ago I used M21/M26 and there was still something on the paint with maybe a spray wax here and there.
    Onto the detail specifics.
    This is what I used:
    Wash: Adams New Car Shampoo, Meguiar's Wash Mitt
    Paint Decon: Ironx, Clay, D155 clay lube
    Wheels: Adams New Car Shampoo, various brushes
    Tires: Meguiar's D143, Blackfire Total Eclipse Tire Gel
    Polish: M205 with a Meguiar's thin yellow polishing pad, D302 with a foam finishing pad
    Coating: Ameriarmour by Americana Car Care
    Tools: Meguiar's MT300 (died in the middle of polishing), PC7424XP
    I started off by using Mike Philips wash method. It is not the first time I used it and it won't be the last. It just saves time. Here's the link to that. Helps if one has a foam gun.
    http://www.autogeekonline.net/forum/...shing-car.html
    Here's ironx at work on the rear bumper
    The one issue that this car has is the typical sail panel adhesive issue. The adhesive seeps through from under the panel. GM no longer replaces the panel under the TSB. Repainting it will not fix it. The only real fix is replacing the panel with one from a 93-97 model. In the heat the adhesive starts to melt and stains the surrounding area. It becomes an eye sore.
    The paint looked pretty good with very minor defects or love marks. It was a bit hard to capture them but they were easily polished out.
    This is the combo I used. M205 on a Meguiar's yellow thin polishing pad and D302 on a black thin finishing pad. I have always been curious about using D302 on a foam finishing pad as it was talked about so long ago on the Meguiar's forum. I wanted to see if I could amp up the gloss and refine the finish even more.
    I was using my Meguiar's MT300 at the beginning and as I was using it for a better part on the front end, it started bogging down and eventually stopped working with the trigger in the on position while on the drivers side fender. Turns out the cord is causing the machine to not operate properly (I have a thread on this if you search under my name). I was bummed as I had only used it on 3 cars and 1 truck prior to this one. It's a good machine when it's working properly. I had to resort to plan B and use my PC7424XP. It's a good thing I had it as a back up.
    I do have to say the new thin pads work very well with the PC. It utilizes it's power more efficiently. I was impressed with the results I was getting. It took a little longer but the PC was a workhorse and got the job done.
    I followed up polishing with Car Pro Eraser and 2 coats of Ameriarmour.
    Sun shot of the corrected paint.
    Here are a few reflection shots in the garage after it was coated.
    The passenger side of the sail panel with more bubbling. No more adhesive residue.
    Pulled the car outside and took some various photos. There is no flake in this paint.
    Various gloss shots. Not bad considering it's white.
    Tires dressed with Blackfire Total Eclipse
    With the engine bay so clean I just used Blackfire All In One Trim & Tire Protectant
    Sep 2005
    Sydney, Australia
    4,313
    66
    Re: 2002 Camaro SS Coated
    Very nice Michael, the car looks great!
    Is this the first time you've coated it?
    How did you like the Blackfire Total Eclipse compared to Meguiars D163?
    Jul 2013
    Lawndale, CA
    5,642
    66
    Thanks.
    Yeah this is the first time I coated it. I was going to do the sealant/wax combo again but with the little maintenance this gets, a coating made sense.
    I like the Blackfire tire gel. It's a thinner consistency than D163 so it's a little easier to spread out. Durability is about the same. What you see is 2 coats and that's as glossy as it gets.
    OCDetailer
    Mar 2004
    Connecticut
    153
    19
    What a cool car! I had a red 1999 Z28, but it didn't look near as good as yours.
    2020 BMW X3M Competition - Toronto Red
    2020 Chevy Bolt - Arctic White
    2019 Fiat 124 Spider - Brillante
    Some look better than others....
    Jul 2013
    Lawndale, CA
    5,642
    66
    Quote Originally Posted by DAC17 View Post
    Thanks.
    Cadillac enthusiast Eldorado2k's Avatar
    Jan 2014
    Los Angeles, Ca
    42
    1,257
    21
    So did the D302 on the finishing pad amp up the gloss?
    Jul 2013
    Lawndale, CA
    5,642
    66
    Hard to tell on white. The paint on this car is hard and M205 alone finished out nicely. The black sail panel is softer paint and M205 left some marring on it. D302 on the finishing pad took care of that. So I am going to say yes.
    Registered Member OTBMD's Avatar
    Oct 2016
    Los Angeles California
    4
    5
    Wow the car looks Nice!
    Jul 2013
    Lawndale, CA
    5,642
    66
    Quote Originally Posted by OTBMD View Post
    Thanks. It's hard to believe the coating has been on the paint for over a year already ( 14 1/2 months). It's performing quite well on my car. Much better than when I had it on my dad's Camaro that was exposed to the elements 24/7.
    Jan 2007
    Rochester Hills, Michigan
    671
    21
    You always post fantastic work, Guz!
  1. 2002 Camaro Z28 Now Coated
    By The Guz in forum Show Off Your Latest Detail Work
    Last Post: Oct 5th, 2015, 10:11 PM
  2. Red 2002 Camaro SS
    By thegooseman in forum Show Off Your Latest Detail Work
    Last Post: Mar 1st, 2015, 04:41 AM
  3. 2002 Camaro Z28
    Last Post: Aug 24th, 2014, 09:29 AM
  4. Camaro Z28 2002
    By Evan.J in forum Show Off Your Latest Detail Work
    Last Post: May 28th, 2012, 03:23 PM
