DUB Wheel Cleaner / Iron-X
Results 1 to 10 of 10
Thread: DUB Wheel Cleaner / Iron-X
    Registered Member Super Dave's Avatar
    Jan 2015
    Chattanooga Tennessee
    96
    6
    I understand that DUB Wheel Cleaner & Iron-X both have the same basic ingredient to attack iron on your wheels or paint. I used it this weekend to remove some spots from my white paint on my 2015 Toyota 4Runner. It definitely found the iron spots and turned color as it should. I let it dwell for around 5 minutes making sure it didn't dry and then rinsed generously with water.
    Just out of curiosity I sprayed the same spots again. Again it turned color in the same spots. I let it dwell for around 5 minutes making sure it didn't dry and then rinsed generously.
    Then I did the above steps for a third time and the same thing happened.
    If these products are indeed removing the iron shouldn't it eventually stop turning color? The same spots showed up three times in a row. Am I doing something wrong? Do I not understand how this product works.
    Jan 2015
    96
    6
    Re: DUB Wheel Cleaner / Iron-X
    Bump
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,465
    63
    Perhaps those iron particles are embedded deep in the paint.
    Sep 2005
    Sydney, Australia
    4,290
    64
    I've actually wondered if these iron decontamination products aren't just a gimmick. I'm not saying that they are, but the sceptic in me sometimes wonders.
    It's relatively easy to make a product react with iron and change color, but just because it changes color, doesn't mean it's actually removing anything (or anything much anyway).
    I'm glad you did this little test and posted, since I've been meaning to try the same thing.
    Jul 2013
    Lawndale, CA
    40
    5,465
    63
    I can attest to ironx working on paint but not DUB wheel cleaner. I had some contaminants that would not come off with a clay bar on my camaro. Hit it with some ironx and it definitely pulled them off. Claying is also easier after using this.
    DUB wheel cleaner works great when used on wheels.
    Cadillac enthusiast Eldorado2k's Avatar
    Jan 2014
    Los Angeles, Ca
    41
    1,257
    20
    How would you describe those contaminants that wouldn't come off with just clay?^
    Were they visible? Or just rough on the paint?
    Jul 2013
    Lawndale, CA
    40
    5,465
    63
    Quote Originally Posted by Eldorado2k View Post
    Visible. They look like little black specs in white paint. Clay did remove those that were not embedded deep.
    Jun 2014
    Sault Ste Marie Ontario Canada
    73
    6
    As long as they are changing color they are still removing the iron, Once they stop changing color the iron is gone
    Jan 2014
    Los Angeles, Ca
    41
    1,257
    20
    In this video review of the DUB Wheel Cleaner, it shows far less color changing on the 2nd application to the wheel. Check it out.
    https://m.youtube.com/watch?v=7L9m-ySCW04
    21,402
    1138
    Everything that we deal with in detailing happens in varying degrees. Bonded contaminants accumulate over time, and the longer you let things go the worse they get. But even the specific iron particles can vary in size and quantity. On the flip side, any cleaner comes in varying degrees of potency as well. Take something like D101 APC, for example: we recommend a couple of different dilution ratios depending on how aggressive of a cleaner you need. Comparing DUB Wheel Cleaner to IronX it's pretty fair to say that IronX has a higher concentration of the iron reacting ingredient... which is also why IronX smells so wonderfully spring fresh (accent on the heavy sarcasm). So, with DUB Wheel Cleaner not being as concentrated/strong/powerful/aggressive as IronX it follows that you may need multiple applications of it to remove all the contaminants present. Just like removal of below surface defects using SwirlX on a foam polishing pad at low speed may require several passes, but the same defects are gone in a single pass using M100 on a microfiber cutting pad. Although both SwirlX and M100 are comprised of an abrasive suspended in a liquid, M100 has more abrasive particles for a given volume, and those abrasives are more aggressive.
  1. Replies: 9
    Last Post: Nov 1st, 2014, 02:33 PM
  2. Tire/Rim/Wheel cleaner safe on Painted Plastic Wheel covers?
    By actionstan in forum Meguiar's Consumer Line Products
    Last Post: Aug 1st, 2014, 11:04 AM
  3. Replies: 4
    Last Post: Nov 6th, 2011, 05:54 PM
  4. Replies: 4
    Last Post: Oct 21st, 2009, 06:18 PM
  5. Hot Rims All Wheel Cleaner or Aluminum Wheel Cleaner?
    By bzimmer in forum Meguiar's Consumer Line Products
    Last Post: Jul 30th, 2009, 06:49 PM
