Marine/RV Trailer Corrosion Protectant
Results 1 to 7 of 7
Thread: Marine/RV Trailer Corrosion Protectant
  1. #1
    Sr. Global Product & Training Spec Michael Stoops's Avatar
    Join Date
    Oct 2004
    Location
    Irvine, CA
    Posts
    21,401
    Rep Power
    1138
    Features:
    • Creates a barrier that protects against corrosion on coated & uncoated metal surfaces
    • Quickly dries clearly & evenly without any residue or drips
    • Self-leveling formula penetrates hard to reach areas
    • Leaves a clear protective coating
    Details:
    • Part#: M77015
    • MSRP: $19.99
  2. #2
    Mr Sparkle davey g-force's Avatar
    Join Date
    Sep 2005
    Location
    Sydney, Australia
    Posts
    4,290
    Rep Power
    64
    Re: Trailer Corrosion Protectant
    Can this be used on car undercarriages?
    Quote Originally Posted by Blueline View Post
  3. #3
    Registered Member DasBurninator's Avatar
    Join Date
    Nov 2014
    Location
    Denver, CO
    Posts
    459
    Rep Power
    10
    Quote Originally Posted by davey g-force View Post
    That was my first thought when I read the description.
  4. #4
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,999
    Rep Power
    90
    Although this product was tested and designed for un-coated & painted trailer surfaces, we don't see any issue with using it for that application davey.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  5. #5
    Registered Member
    Join Date
    Oct 2019
    Location
    Canada
    Posts
    2
    Rep Power
    1
    Hi Nick,
    Would you recommend this product as the best approach for protecting a vehicle hitch? Only recommendations I've seen on the web tend to be grease, WD40 or fluid film. I know all of these powder coated hitches eventually rust but I'd like to delay that as much as possible given I have a brand new hitch installed. I see very little discussed about this product.
    Thanks!
  6. #6
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,999
    Rep Power
    90
    Quote Originally Posted by fromoutwest View Post
    Hi Nick,
    Thanks!
    We did not design or safety test this product to be used directly on the trailer hitch ball (or any other apparatus where the tow vehicle connects to the trailer), so do not recommend it for this use if that is what you are referring to. However, as long as you do not spray it directly on the ball or any other apparatus where the tow vehicle connects to the trailer, it should work great to add protection.
    Hope this helps feel free to post further questions.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
  7. #7
    Registered Member
    Join Date
    Oct 2019
    Location
    Canada
    Posts
    2
    Rep Power
    1
    Thanks Nick - intent is to spray primarily around/inside the receiver area as that is what really starts rusting out after 2-3 years typically. We only use the hitch for bike racks and keep plugged with a cover when not in use, thus not using a hitch ball. I think taking the rack in and out over time is taking off the powder coating and leaving bare metal inside which eventually starts rusting. Do you think this product will help in this case? Also, I noted it appears the product is discontinued? Hopefully can find somewhere if you think it may work as I suspect should last quite a few years given the small surface area.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Corrosion on factory wheels
    By Walden90 in forum Introduce Yourself - New Members
    Last Post: Mar 27th, 2010, 07:43 PM
  2. How to fix corrosion on rims?
    By spotdog14 in forum Detailing 101
    Last Post: Jul 29th, 2009, 06:17 AM
  3. Aluminum corrosion in Engine compartment
    By steve911 in forum Engine Compartment Detailing
    Last Post: Jun 14th, 2009, 01:24 AM
  4. Aluminum wheel corrosion
    By Dieseljoe in forum Detailing 101
    Last Post: Apr 15th, 2008, 01:42 PM
  5. Wheel corrosion around center cap
    By petepuma01 in forum Detailing 101
    Last Post: Apr 14th, 2008, 08:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
