Hi everyone.
I just started cutting and polishing and am trying to build up my tools and supplies.
So far i have a rotary buffer along with a pad kit i bought for it.
It came with a backing plate, 80-120-220 grit paper and a terry cloth like pad. http://www.harborfreight.com/7-in-po...-pc-69589.html
I bought it from HF, where I get most of my stuff.
Im using meguiars UC/UP and m105/205 for different cars.
My question, what is the terry cloth pad for? cutting scratches out, polishing, or waxing old paint jobs?
I also bought a thick wool buffing pad(backing hook n loop) they sell. I used this pad and it made little cuts on the paint surface. Im thinking its too aggressive for paint that hasn't fully cured. http://www.harborfreight.com/7-1-2-w...ffing-pad.html
I also have a thin fleece bonnet, just has an elastic band and is wrapped around whatever it is put on. which could be used for...?
Another question,
Harbor freight sells 4 foam pads(hook n loop backing) which I plan to use to cut and polish.
Yellow-buffing pad http://www.harborfreight.com/9-inch-...pad-91235.html
orange-compouond pad http://www.harborfreight.com/8-in-co...pad-61530.html
blue-polishing pad http://www.harborfreight.com/8-in-po...pad-61531.html
black-finishing pad http://www.harborfreight.com/8-in-fi...pad-61529.html
So which ones of the colored pads should I be getting for cutting sanding scratches out? yellow or orange? I don't want to make cuts in the paint with the thick wool pad anymore! Both colors say compound/cutting. yellow says buffing pad and orange just says foam pad.
And I should get the blue pad to apply polish after i use either the orange or yellow pad right?
What wax product is best recommended to use with the black finish pad? Description says use with wax for a swirl free finish, is this pad even needed?
Thank you in advance!
Another question,
