Eliminating Cigarette Smoke Odor
  • Eliminating Cigarette Smoke Odor
    Hi, sorry if this has been covered before, but I just joined the forum.
    Any recomendations on how to remove/eliminate the smell of cigarette smoke from inside the car?
    Re: Eliminating Cigarette Smoke Odor
    Hi kobesbus.......Welcome to MOL
    I would start by cleaning the upholstery & carpet....Then the vinyl & glass....I guess the headliner could could use a cleaning too, but I've never had much luck there without causing stains.
    It may take a while for the nicotine odor to go away, but Meguiars sells a product to help remove orders.......
    I've never used it myself, but others have commented on how good it works.
    r. b.
      Thanks for the welocme and the info. Will buy a bottle and try it. Almost anything should help! - but this stuff looks good. Q, why would it leave a stain on the headliner and not on the carpets? My interior is all black.
        I'm just going by my own experience here, but I was not referring to the odor eliminator causing stains in my headliner.....The stains were caused by different upholstery cleaners that I've tried.
        But my headliner is a very light gray too, and that makes it easy to see stains on it.
        r. b.
          While the odor eliminator will help to a certain extent, smoke ordor is probably one of the hardest smells to remove. The reason for this is that ash tends to go everywhere, into the A/C system, into the dash, into every little nook and cranny. If you don't remove the source of the odor, you can't really ensure that you have removed the smell itself. Cleaning will go a long ways, but unless you dismantle your interior, the smell will continue to linger. An ozone machine would probably do the best in that situation, but if you don't mind using the odor eliminator regularly, it would help.
            I cleaned up a smokers car once, and I never thought that I would get the inside windows clean. Brown nicotine stained the paper towels over & over again.
            Imagine that inside your lungs.
            r. b.
              Yea, I have a 1991 Toyota Corolla, and 226K miles, the 2 owners (my relatives) were all smokers. I dismantled my whole dash and used NXT Protectant and boy did it smell fruity for 2 weeks =) Soon I'm going to take my whole dash all the way to the defroster. For me I get a kick out of cleaning and protecting to make a 16 yr old car brand spanken new. BTW I used the Meguire's Clay on the 16 yr old paint job (white), well lets just say I've only used 3/4 of one of the bars (cut the bar into 4 1/4 pieces) and let just say it just came out of the factory, if you don't look at the rust spots and rock dings =P
