Orbital and wax
Results 1 to 9 of 9
Thread: Orbital and wax
    Nov 2009
    Yeppoon QLD Australia
    14
    Orbital and wax
    I no a lot of people will disagree, but I find a cheap orbital is great for applying and removing wax. I can do it in half the time. And it does just a good of a job, in my opinion. After I remove the wax I go over it with a microfiber cloth to finish it off.
    Sep 2008
    Sydney, Australia
    1,352
    25
    Re: Orbital and wax
    For applying and removing wax, yes an orbital polisher is quite good!
    It's when you come to doing any corrective compounding or polishing the orbital polishers tend to be out of their depth. That's when a DA Polisher or even a Rotary polisher really come into their own.
    Apr 2007
    US
    1,119
    25
    Re: Orbital and wax
    I don't disagree at all. My little orbital is pretty much all I need to use. Contrary to some, it can take out some fine lines, with a little work, and a good polish. Of course it will not work for more pronounced flaws, but if your paint is good, it is a fine little tool to save time and the elbow. I only use mine to apply the final wax as I prefer to remove the residue by hand.
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    16
    Re: Orbital and wax
    Yep, I use a DA, but it's the same idea. A little cleaner-wax and you've got a mild correction. I don't use it to remove (D301), though. It's a quick wipe though, no buffing.
    First Correction | Gallery
    Sep 2015
    Ohio, Ohio
    3
    5
    Re: Orbital and wax
    Hi, I am trying to decide the best applicator pads to use on my 10" and 6" what type of material do you all use for applying the wax, and then using the buffer what material do you use to remove the wax. Since there are about 1000 various materials out there, it can get very confusing. I still do my Lincoln and Thunderbird by hand, but we have a large F150 that I want to try using the buffer before my arms fall off Thanks all!!!!
    Jun 2014
    Sault Ste Marie Ontario Canada
    82
    7
    Re: Orbital and wax
    Quote Originally Posted by Top Gear View Post
    I always use my DA to apply products but use towels to remove. rarely buff
    Sep 2015
    Ohio, Ohio
    3
    5
    Re: Orbital and wax
    Thanks Top Gear! I am assuming microfiber bonnets are appropriate to apply?
    Apr 2007
    US
    1,119
    25
    Re: Orbital and wax
    Quote Originally Posted by Lyman1234 View Post
    I am fairly confident Top Gear would be using some type of foam pads on his DA. I believe you are planning to use a small orbital buffer which takes a bonnet type applicator. If that is the case, then yes, microfiber bonnets are fine to use to apply. That is what I use to apply, but buff off by hand.
    Sep 2015
    Ohio, Ohio
    3
    5
    Re: Orbital and wax
    Thanks Blueline, exactly what I was looking for. Appreciate this!!
  1. Random Orbital vs Dual Action Orbital
    By fredcandetail in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Mar 8th, 2011, 05:03 AM
  2. When to use my orbital
    By 3Fitty in forum Detailing 101
    Last Post: Apr 8th, 2008, 07:42 PM
  3. #83 w/ orbital
    By JTeg360 in forum Detailing 101
    Last Post: Apr 30th, 2007, 07:07 AM
  4. can the #80,#82,#83 be used with an orbital???
    By specr89 in forum Detailing 101
    Last Post: May 13th, 2006, 05:10 AM
  5. pc or orbital??????????
    By ercoreca in forum Detailing 101
    Last Post: Jul 23rd, 2004, 01:30 PM
