Removing sand from carpets
  • Removing sand from carpets
    I heard some guys talk about using a sander to vibrate sand out of carpets so I thought I would give it a shot. WOW. The mat shown was vacuumed and blown out with a tornador, it still had a small beach coming out of it. Great for inside the car too.
    www.JaxDetails.com
    www.facebook.com/DentsAndDetails
    I may be slow, but I do poor work.
    Re: Removing sand from carpets
    That is amazing! Great tip!
      That's inspired! Maybe a DA will also work, holding the plate still and hanging the mat against it?
      First Correction | Gallery
        need to brush it with a good stiff brush.to remove as much sand as you can..left.right.up..and .down.then put the shop vac to it.may take a few time...
          Interesting tip. I gave your vid a thumbs up. Thx for posting.
            Great idea! How does it work on carpeting that cant be removed? Loosens it enough to be vacuumed or should I just stick to the floor mats?
              I'm thinking if you held your vacuum hose beside the sander/DA w/brush, as you move around the carpet or mat, you could save even more time. Nice tip!
