First time I used M21 and I applied it with the W9207 (the 7 inch foam finishing pad) mounted on my PC DA. I should mention; I love the results! Just want to get better at this.
I'm wondering (actually, I'm pretty sure) if I loaded the pad too much because when I was finished and washing the pad, the sealant just kept coming out of the pad in clumps as I was wringing it out. Looks like I used about a third of the 16 oz. bottle, too. I thought I'd load the pad similar to loading the microfiber cutting pads with compound but I'm sure I wasted most of the product so I'm wondering; what's the best way to load the pad with sealant? Is a foam pad the best way to apply it with a DA? The bottle does note other Soft Buff pads to use but wondering if there's an alternative.
Second question is; what's the best way to remove it? I'm interested in removing it in order to do some paint correction later this summer. I heard that clay will remove it and wondering if it' easy to tell if/when it's been removed.
Third; can this be applied to a vinyl wrap or should it only be applied to paint? If not, am I "limited" to using wax?
Thanks in advance!
Thanks in advance!
