#67/red cutting pad/DA not enough
  • #67/red cutting pad/DA not enough
    I need more gel coat correction. I know that I have more powerful choices available such as rotary/wool/91. Which do you suggest and will I need an intermediate correction step before polish and/or wax?
    Thanks,
    George
    Re: #67/red cutting pad/DA not enough
    105 is pretty aggressive with a red pad.
      I found an old chart that shows:
      91/wool
      67/red
      so thats one approach. However I also have read many posts that suggest that with old abused gel coat such as I have that cutting just opens the pores of the dried out gel coat and makes it worse. I am wondering if I should even start down the 91/wool path. It's pretty blotchy after 67/red.
      Any thoughts?
      Thanks.
        I worked out the following after doing some sections/experiments and will try it out on the entire front brow of the boat, which is a lot of real estate:
        Yellow/45/DA
        67/wool/rotory
        67/red/DA
        61/yellow/DA
        63/hand
        I found that the uber dry gelcoat soaks up the 67 polish and makes it blotchy hence the 45 "pre soak". It still drags a little so the second 67 step smooths it out. BTW, I was a 49/45/56 guy for decades but 67/61/63 is a serious upgrade although 67/61/Collonite paste is just as good. Also a lot of the guys here like:
        3M Perfect it/wool/rotory
        63/wool/rotory
        but I have not tried it.
