No wheel brightner avalible for purchase at Meguiars.com in the professional section ... When will the product be avalible. ?
No Wheel Brightner
I don't think it is going to be available online. From what I remember, I think meg's wanted to limit the possibility of an inexperienced detailer damaging their wheels with this product. Since there are multiple dilutions, it takes a pro with experience to know which is right and on what types of wheels it can be used on.
Originally posted by Fr0zen
Well I have used plenty of wheel cleaners in the past from A2Z to a acid based wheel cleaner a friend gave me, who works at a dealer. I would love to give wheel cleaner a try.
BTW, regarding wheel brightner is it diluteable ? Also how does it smell, death in a bottle or grapes ?r. b.
I had the same problem by just removing the cap!
This product has some serious fumes.
I wouldn't recommend a person with asthma to be around it.Last edited by rusty bumper; Jun 12, 2005, 04:06 AM.r. b.
Maybe it's just a problem related to me......Maybe others won't experience what I experienced with the fumes.
The 1st time I opened the jug, the smell didn't overpower me at all, but I found my breathing a little tight, as well as a dry throat to match.
I called a Meguiar rep about it, and he said that it couldn't possibly be the WB that cause my problem, but he did offer to refund my money if I would send the gallon jug back to him.
I think I'll just keep it for now and use the mask when I clean wheels with it.
I like the product.......But not the fumes.r. b.
We use gallons and gallons of wheel brightner. First off let me recommend you read the MSDS and the precautions on the bottle.
Before you use it start with the best wheel cleaner in the world, soap and water. We clean the wheels with soap and water first and only use wheel brightner if the first cleaning with soap and water doesn't bring satisfactory results. Most of the time sopay water is good enough.
Also, when we do use wheel brightner we mix it 10:1 and not 4:1. I rather apply cleaner twice (or three times) than to apply a to strong of a mix one time and damage or stain the rim.
Keep in mind that wheel brighner will stain concrete. We still use it if the vehicle is parked on concrete but we make sure to rinse the area around and under the tire thouroughly.
Wheel brighner is a good product if used correctly and safely.
I never thought about changing the dilution ratio, but I guess it would be better than staining a wheel.r. b.
