Clear coat safe rubbing or Ultimate compound
Results 1 to 10 of 18
Thread: Clear coat safe rubbing or Ultimate compound
    Registered Member snozan's Avatar
    Jul 2016
    Sweden
    42
    210
    6
    Hello =)
    Tried to search, tried to google, but without any luck.
    My car a black VW -02 hasn't got any love since new (just bought the car). So i thought i would give it a go. Am not after perfection and am going to do it by hand.
    So i have looked at some products and come up with 2 options: Clear coat safe rubbing and Ultimate compound. In my mind the "clear coat safe rubbing" would be the best option since it's made to use by hand. However i havn't found anything about it. How to use etc.
    This is how i think i'll use it. just rubbing it in untill am happy? Not like other products where you wait until "a matte surface occure, then wipe it off".
    As a final stage i have bought the paint protect 365
    Am just unsure how to use the Clear coat safe rubbing, since this is oki here it comes: the first time i ever use Meguiars products :/
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,419
    62
    Re: Clear coat safe rubbing or Ultimate compound
    Get yourself ultimate compound. It can be used by hand.
    Nov 2004
    SoCal
    2,307
    41
    Cool Re: Clear coat safe rubbing or Ultimate compound
    Quote Originally Posted by snozan View Post
    ...This is how i think i'll use it. just rubbing it in untill am happy? Not like other products where you wait until "a matte surface occure, then wipe it off"....
    Correct, only waxes and sealants need to dry before removing the residue. They work by leaving something behind.
    Compounds and polishes do their job as you rub them against the finish. When you're done rubbing there's nothing more for them to do. They should be removed before they dry.
    Jan 2007
    Rochester Hills, Michigan
    577
    18
    Ultimate.
    Jul 2016
    Sweden
    42
    210
    6
    Thanks for reply Ultimate you say...
    So what's the real difference between "Clear coat safe rubbing" and "Ultimatre compound"? Which one is most bullet proof? Saw some serious pictures yesterday here on a car when things got really really wrong with ultimate compound.
    Jul 2016
    Sweden
    42
    210
    6
    Oki i searched some more. And i think i came up with the answer myself?
    Clear coat safe rubbing is a "DAT"
    DAT products use a kind of abrasive that becomes smaller and smaller as it is worked against the surface. The 80 series polishes (85,84,83,80) use this kind of technology. They have specific work time and you have to work through that entire work time because the abrasives need to break down and keep polishing the surface. If you stop working the prodict too soon, there may be some hazing due to the abrasives not breaking down all the way.
    And Ultimate Compound is a "SMAT"
    SMAT stands for Super Micro Abrasive Technology. Products like M105, M205, Ultimate Compound, Swirlx, Scratchx 2.0, M86 and D151 all use SMAT. This means that the abrasives do not break down. They are extremely small and do not break down upon working the product. This allows detailers and technicians to work the product as long as they need to, not as long as the product needs to. SMAT saves time in this manner. Furthermore, SMAT allows a compound like M105 to finish out very nicely and in some cases, it can be used as a finishing polish! Finishing polishes like M205 can also bring clarity to a finish that M80 Spped Glaze simply can't do due to the abrasive technology. This is why M205 and M205 is one of the most popular compound/polsh combos out there.
    If so, there is no question about what to use. I want to decide when its done without having to add more to get the job done
    Read more at http://www.meguiarsonline.com/forums...1CCecbQLGyj.99
    Registered Member rytec's Avatar
    Aug 2013
    Flanders Belgium
    29
    7
    Quote Originally Posted by the other pc View Post
    Kidding me? So you do not need to remove it with a microfiber towl after you have put it on the surface with the yellow pad by hand? In the manual it says turn 4-6 times over the same part and then wipe it off with a microfiber towl.
    Jul 2013
    Lawndale, CA
    40
    5,419
    62
    Quote Originally Posted by rytec View Post
    Of course you want to remove a compound or polish. You do not want to let it dry on the paint unless you want to make things harder on yourself.
    Aug 2013
    Flanders Belgium
    29
    7
    Yes I thought the same and do it always that way, but I understood it wrong in the sentence of "the other pc" because he said they should be removed before they dry and I thought that you needed to turn and turn untill you couldn't see any of the stuff anymore, my mistake of interpretation
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    15
    rytec, all of this is very overwhelming. All of us had to spend time figuring it all out, and there's not really any easy answers. Heck, some waxes do not need to, and should not, be left to dry, if that makes the point. I use Detailer D301 Finishing Wax, and it's designed to be wiped off immediately with one wipe. The old days of lathering on a wax by hand and waiting all afternoon for it to dry, then spending an hour or more trying to remove the excess and buff it out are over. It's just too much work. Also, everything Meguiar's makes is "clear coat safe", I believe.
    Some pictures would help us gauge what your paint might need and we can help you with better information than just shouting brand names at you Meguiar's makes a LOT of products, but what is it you're trying to accomplish, and how much time do you have to devote to periodic "cleanup" or "correction" and regular "maintenance", meaning regular washing and spray waxes??
    First Correction | Gallery
  1. Rubbing compound for oxidation/clear coat failure
    By Bret11 in forum Working by Hand
    Last Post: Feb 8th, 2015, 12:21 PM
  2. Replies: 5
    Last Post: Nov 27th, 2012, 08:38 PM
  3. clear coat safe rubbing compound function
    By ahjun in forum Working by Hand
    Last Post: Feb 16th, 2012, 06:30 PM
  4. M105 Ultra Cut Compound - Clear-coat paint safe???
    By Vettefan in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Dec 3rd, 2011, 02:59 PM
  5. Difference between scratchx, swirlx, colorx and clear coat safe rubbing compound ?
    By svtstangcobra in forum Meguiar's Consumer Line Products
    Last Post: Aug 30th, 2011, 02:42 PM
