Sealant vs Coating
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Sealant vs Coating
    Jun 2016
    Flushing NY
    37
    4
    Sealant vs Coating
    Besides longevity is there really a difference between coatings and sealants?
    From my readings, I see many statements lowering the hype about coating such as "Hardness can help aid in some levels of protection, but on the scale of 1-3 microns which is the average thickness of a coating, it doesn't directly do much. There is little to no evidence that coating hardness plays a role in scratch resistance. " https://itsbetterwaxed.com/blogs/det...prevent-swirls.
    I know coatings help washed induced marring due to less surface tension but doesn't a sealant do the same?
    So my question is, if I don't mind applying a sealant every 4 months, does a coating provide any other benefits?
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    Re: Sealant vs Coating
    Yes it does. Coatings also protect better against chemicals, bird droppings. A car stays cleaner longer in between washes. Not to mention that a vehicle that is coated is easier to wash.
    If the sealant is working out for you and you enjoy polishing more frequently, then stick to that.
    Jun 2016
    Flushing NY
    37
    4
    Doesn't that fall into the if I don't mind doing it more frequently it is the same? Like my sealant is known hold up for 8 months. If I reapply every 4 months, would it not do everything above equally as well?
    My main concern is my car is street parked. So I am worried about people rubbing up on the car, tree branches, flying debris from moving cars etc. Will a coating offer better protection for those scenarios?
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    Quote Originally Posted by DanielM View Post
    To quote Mike Phillips find what you like and use it often. Coatings are not for everyone. Coatings are semi permanent and offer a longevity of about 2-5 years. Professional coatings can last up to 7-10 years. Another added benefit to a coating, is that one does not have to wax or spray wax it. Some coating manufacturers include sealants that have the same chemical make up as their coating to maintain it. For example cquartz and reload. Coatings still require some maintenance.
    Coatings will not protect from tree branches or flying debris. If you want to protect against that then consider paint protection film like xpel. Coatings are not miracle products and are not the end all be all.
    Jun 2016
    Flushing NY
    37
    4
    Thank you for the prompt response. The problem with "find what you like and use it often", is I like the best =) but I don't like to unnecessarily waste product.
    So that kind of takes away from the ease of coating no? I see many debates on the need for layering.
    Last two question if you would be so kind:
    1. Does a coating like opti-gloss stand up to a light abrasive polish? It would be great if it captures minor swirls and can be buffed while leaving my clear untouched.
    2.Do you find coating live up to the hype of a mirror finish? The problem with many coatings is the paint must be stripped of all oils. Sealants allow and also have glazes that can be sealed in. I would think that would give a better shine no?
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    16
    IMO, so-called "sealants" (waxes by a synthetic name) and coatings are way over-hyped. 100% marketing claims can be powerful, but if a daily driver, your car will still get dirty, and you will still need to wash it and care for it. A coating does not magically keep it clean, and a sealant will not outlast any given wax when it comes to daily/weekly maintenance that must be done. Use a sealant happily if that's the "look" you want (bright gloss), but do not be fooled for a moment into thinking the paint has literally been "sealed". Any wax on the shelf will last just as long under the same conditions and with the right care. Coatings may "seal" the actual finish, sure, but that coating still gets filthy, looks dull, and needs to be cared for, just as much as the paint does. It's all pretty much hype, in my view. A great Meguiar's carnauba wax is all you need, and the finish will look so much better and natural (dark, wet gloss). The maintenance is still the same no matter what: Regular use of the duster, waterless wash, detailer, spray wax, and careful washing when you need it. I can and do go many months on end without having to break out the DA and re-wax, and in the meantime, the finish always has that Car Crazy Meguiar's carnauba look
    First Correction | Gallery
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    You may not like this answer but there is no best. If you are looking for a product that offers longer protection, more durability and better chemical resistance then go with a coating. If you like to polish often then a coating is a waste of time, product and money. This is where you stick with a carnauba or sealant.
    I don't think so. A coating still needs to be washed. It's not a apply, set it and forget it type product. The idea behind is that surface contaminants are still going to get on the surface. Contaminants will hinder the sheeting and beading properties of the coating. A sealant made of the same chemical make up restores that beading and sheeting as people like to see that. Just because the beading and sheeting has been altered a bit, it does not mean it is not on the paint protecting it.
    There are many folks who believe that a wax, sealant or spray wax applied to the top of a coating will protect the coating so it lasts even longer. That is an ongoing debate. But also note that a sealant or wax applied over the coating will alter the beading and sheeting to the properties of the topper.
    The answer would be no. An abrasive polish will remove gloss coat. Defects (marring, swirls) will be in the coating. A polish will remove the coating.
    I am going to say yes. I have used gloss coat on 3 vehicles. It not only looks great. But with proper maintenance (washing) the vehicle will look great for a long time. There is a video on the rag company youtube channel which goes into detail on how to clay gloss coat without affecting it on the surface. I recommend you watch those videos.
    You are correct. A coating needs to have the paint removed of all polishing oils from the surface for it to bond properly to the paint. If not, it will compromise the coating. Gloss comes from properly prepping the paint aka polishing. Glazes fill in minor imperfections but a glaze does not last long even if it is sealed by a sealant.
    I have polished and coated all of these and they sure do look great. Their glossy appearance lasts much longer than a wax and sealant.
    http://www.meguiarsonline.com/forums...IhsAvAuQaG3.97
    http://www.meguiarsonline.com/forums...HzEjq4I4I01.97
    http://www.meguiarsonline.com/forums...saS3R6USfuZ.97
    http://www.meguiarsonline.com/forums...rOjdoCjxZ6L.97
    http://www.meguiarsonline.com/forums...Qe34JhpCdbi.97
    I just completed a black 2002 Corvette that I coated with gloss coat. Write up coming soon but it looks amazing and has amazing gloss.
    If you are looking for a coating to venture into, I would recommend gloss coat. It's is very easy to use and it is a great product. Check out episode 6 of the optimum synergy podcast.
    Quote Originally Posted by Top Gear View Post
    They are not hype at all. Waxes, sealants and coatings all do what they are intended to do. Science has proved the longevity and durability of each product.
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    You may like this video as well.
    https://www.youtube.com/watch?v=vdEPP-OnV9A
    Jun 2016
    Flushing NY
    37
    4
    The Guz, I know I said one last question but this above quote intrigued me. So if I use a very light abrasive polish like swirlx, I could basically remove the swirled up coating and apply another coat without ever touching my clear?
    I guess I thought it was hype when I see people who claim to paint correct 4x per year saying they will never need to correct again. Correct me if I am wrong but If you swirl clearcoat that bad, wouldn't you would swirl coating no?
    Wow, those pictures look great. Are you able to use a DA buffer with coating or only hand application?
    You are winning me over. Damn you!!! I just bought GG AIO sealant, so it would be useless since it has polish in it if I buy glosscoat.
    I just wish it was cheaper like sealant because I am still new at this.
    I really appreciate the replies to all my threads. I am new at this.
    Jul 2013
    Lawndale, CA
    41
    5,533
    64
    Gloss coat does cost more but in my opinion it's worth it considering it is now an up to 3 year coating. There are a few other coatings that are cost effective. Head over to autogeek and look at McKee's 37 paint coating or Duragloss. Both are easy to use. McKee's 37 is a forum favorite. I have also used Pinnacle Black Label paint coating which is very easy to use. There are quite a few.
    I'm a pro gloss coat guy as it's so easy to use and it looks great with the proper prep. The fact that it is a flexible coating meaning it expands and contracts with the paint is another reason it won me over.
    Most coatings are applied by hand. For example see this video on how easy it is to apply gloss coat
    https://www.youtube.com/watch?v=ctFtza_jGxs
    Pinnacle Black Label and McKee's 37 are sprayable coatings which are just as easily applied.
    Say you need to touch up an area, you could simply polish that area and recoat it. For example if there was some sort of defect on a door, I would polish the entire door and recoat it. If you had a small polisher like the Rupes nano then I would just hit the small area that was touched up.
    If you properly wash the car and maintain it properly you will not have to take a polisher to the paint. In theory the coating is the part that will get swirled.
    You are correct any cleaner wax, compound or polish should not be used on a coating. Even clay could cause a problem as it is abrading the surface. This is different between all coatings.
    I also like the optimum synergy with their products. Check out McKee's 37. It's quite affordable.
    This video is for Pinnacle Black Label but the McKee's 37 uses the same application. Pinnacle Black Label is an up to 3 year coating and McKee's 37 is an up to 2 year coating. Both are similar in their chemical make up.
    https://www.youtube.com/watch?v=flwBh6zz_5M
    As much as I like sealants, I am pro coatings. I don't even use carnauba waxes anymore.
  1. Meguiar m20 poly sealant vs m21 synth sealant
    By DJMagnum in forum Detailing 101
    Last Post: Nov 11th, 2015, 09:27 PM
  2. can m21 2.0 sealant be use as plastic headlight sealant?
    By apollofin in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Nov 11th, 2011, 07:37 AM
  3. Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant
    Last Post: Sep 29th, 2010, 10:13 AM
  4. Sacrificial Barrier Coating = The purpose of a wax or synthetic paint sealant
    Last Post: Sep 9th, 2010, 06:25 PM
  5. Replies: 3
    Last Post: Mar 10th, 2007, 05:48 PM
