Cloudy/drippy clear coat
Results 1 to 4 of 4
Thread: Cloudy/drippy clear coat
    Aug 2016
    Los Angeles California
    5
    Question Cloudy/drippy clear coat
    I noticed these issues with my car after a very hot summer season a few years ago. To be honest, it looks more like damage from cleaning chemicals at a car wash than heat damage - but it has now been way too long to go seek restitution for this.
    Using Ultimate Compound and Ultimate Polish (and a lot of elbow grease!) can remove it temporarily, but it always comes back. What is this exactly? Is there a more permanent fix that doesn't involve a huge hit to my wallet? Cheers.
    https://imgur.com/a/DUrF5
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    17
    Re: Cloudy/drippy clear coat
    Looks like soap chemicals left on and baked in by the Sun, staining the clear coat because it wasn't protected at the time.
    Because it keeps coming back, you're going to have to get a lot more aggressive and "professional" than using UC/UP by hand. You're not really cutting into the problem - just coating it with polishing oils temporarily. Fixing it will require use of a DA polishing machine, like a Porter Cable, with quality pads, like Meguiars microfiber. It will require a full multi-step correction, or it may also require wet-sanding followed by a full correction. You can buy all the products and learn the techniques, or pay a pro to do it. Who knows, it might even be a candidate for a Meguiar's Open Garage event (not that I'm volunteering them). However it's fixed, the finish needs to be properly washed and waxed and maintained so that soap doesn't dry on the surface, and even if it did, doesn't easily etch into the clear coat itself.
    In short, I think it's fixable, but could require most or all of the techniques we all talk about here, in many hours of proper correction. It's not going to be an easy 5-minute $10 fix.
    First Correction | Gallery
    Aug 2016
    5
    Thanks for the info. I think i want to go at this myself. What does a "full multi-step correction" entail? Is it: wash the car with harsher soap to remove outer layers, clay affect areas, DA machine for compound + polish, and finally wax to coat the surface?
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,644
    66
    Seeing as you are local, you may want to head over to a Thursday night garage or Saturday class to get some hands on training.
  1. Replies: 0
    Last Post: Sep 22nd, 2015, 01:59 AM
  2. cloudy and pitted clear coat?
    By guitar1969 in forum Detailing 101
    Last Post: Aug 6th, 2013, 02:40 PM
  3. Clear coat turns white when wet, clear after drying
    By invstor17 in forum Detailing 101
    Last Post: Jul 11th, 2012, 06:01 AM
  4. cloudy spots in clear coat
    By norsk in forum Detailing 101
    Last Post: Sep 25th, 2009, 08:27 AM
  5. Cloudy clear coat
    By nogrille in forum Detailing 101
    Last Post: Jan 7th, 2005, 08:35 AM
