Hi all!
I really need your help! I just bought a 2016 Nissan Rogue SL AWD in Black Metallic. Originally, upon purchasing, I had some small surface scratches. As a result, I washed the car and attempted to remove the light scratches with a yellow megs foam pad and Scratch-X. Well, it did remove the swirl marks, but it put holograms in the car. I have NEVER had this happen when using Scratch X by hand, and was really frustrated when I saw this. Does this indicate delicate paint?
My next step was to use Megs Color-X on the entire car to really clean up the paint. Well, the paint looked better, but the drivers and passengers side doors have major holograms all over the entire panels now! UGHHHH! What happened hear? I applied with a yellow megs foam pad, let the wax haze, and then removed it with a yellow MF towel. This is when I noticed even more holograms. Honestly, I have never had paint issues like this.
So, my next phase was to apply Swirl-X to the "holograms" with a Megs Foam Pad, and then immediately wipe off the remaining polish. How much pressure and how hard do I want to work the Swirl-X in? Can I apply in circular motions? I have also read that UC is good. Do I want to do that before the Swirl-X. I am only leery of this because when I applied it before Scratch-X to get a deeper scratch out with UC, I had to go over it with Scratch-X as it left my paint hazy.
I really need some help. Short of a professional detailer, how do I remove the holograms on this paint?
