PC pad storage
Results 1 to 7 of 7
Thread: PC pad storage
    May 2005
    187
    17
    PC pad storage
    What's the best method for storing the PC pads? I keep them in open zip-locks all stored in a box together. My question mainly applies to how they never dry...is that okay? I usually wipe them off with a terry cloth because turning the PC on and cleaning with a toothbrush slings product all over. Should I set them out in a clean place, like my kitchen, to let them dry?
    Thanks
    Dan
    "Do the job right, or don't do it!" - Dad
    Registered Member soonercivic's Avatar
    Mar 2005
    280
    17
    when i clean mine i set them in front of an open window over night and they are totally dry in the morning. if you dont let them dry, i would be concerned that they would get mold in them. especially if you store them in a dark place, like a tool box.
    58
    24,767
    518
    Here at Meguiar's 'we store them in a closed cupboard, no plastic bag. The cupboard keeps them from getting dirty but also allows them to dry. At home I place my pads face up on a shelf in the garage and let them air dry. Before using always clean my pads on a rotary buffer using a nylon brush to remove any dried product and to insure no dirt or other contaminants have fallen on it.
    May 2005
    23
    15
    I gave my G-100 its first workout on Saturday. I did my friends car with M-09 and M-07. The W-8006 that I used for the M-09 got really soaked. When I took the pad off the backing plate I saw that product had made its way through to the velcro. The W-9006 that I used for the M-07 wasn't nearly so bad.
    Did I use too much product?
    58
    24,767
    518
    Originally posted by Mini-T
    I gave my G-100 its first workout on Saturday. I did my friends car with M-09 and M-07. The W-8006 that I used for the M-09 got really soaked. When I took the pad off the backing plate I saw that product had made its way through to the Velcro. The W-9006 that I used for the M-07 wasn't nearly so bad.
    Sounds like it...
    Cut down on your product use. After applying some product to the pad, the first thing you want to do after placing the pad against the finish and turning it on, is to spread the product out over the area you're going to work, and then start working it in.
    In the case of pure polishes and waxes, it doesn't take a lot of product because all you're really trying to do is to spread on a thin film.
    Nov 2004
    SoCal
    2,300
    41
    Like Mike said it's best to use less product. But if your pad does get soaked you can hold it between microfiber towels and squeeze a lot of the oils out. The microfibers will absorb the oils, they dry fast, they hold up to oils and solvents and they're easy to wash.
    PC.
    Registered Member RamAirV1's Avatar
    1,990
    37
    I set my PC pads out to dry in the open inside my house (AC on, low humidity) and it takes them a couple of days to dry out. That is why I keep procrastinating on cleaning them.
    I suppose I need to wring them out more, but I thought I did that before.
    RamAirV1
  1. winter storage
    By barry in forum Detailing 101
    Last Post: Oct 27th, 2008, 07:16 AM
  2. Meguiars Storage
    By Iluv2zmzm in forum The Break Room
    Last Post: Jun 23rd, 2006, 05:19 AM
  3. Pad storage tip
    By danielsan in forum Tricks of the Trade!
    Last Post: May 4th, 2006, 12:01 PM
  4. Storage
    By Djmigs in forum Machines - The Dual Action Polisher
    Last Post: Oct 27th, 2005, 08:52 PM
  5. PC Pad Storage Idea
    By Chris Nemlich in forum Detailing 101
    Last Post: Oct 7th, 2004, 04:50 PM
