I have been debating on moving over to headlight restoration systems that use clear coat uv protection instead of my normal sanding and polishing techniques. I have heard a few people griping about the orange peel from spraying the coatings. Not many have shown enough evidence for me to know how much orange peel it actually is. Maybe its an over blown complaint. What opinions do most of you have that have used a kit like the perfect clarity kit? Is this coating strong enough to withstand 3000 grit sanding once it has fully cured to reduce the orange peel? Are there other possible methods for getting rid of the orange peel? Another question I have is, what kind of grit sctotch bright pad is included in the kit? Will it be enough to remove and flatten out the defects of even the worst headlights? Is there a professional version of the perfect clarity kit that can be purchased in bulk if I do decide to switch?
Sorry for all of the questions but I plan to make a true business out of this soon and some of my current clients can be rather picky. I`m sure a lot of the forum members can relate to that.
