Professional Mild Clay Marred my paint
Results 1 to 8 of 8
Thread: Professional Mild Clay Marred my paint
    Apr 2014
    Sacramento
    3
    7
    I typically use the standard store bought clay kit but went for the Professional Mild clay from Amazon. The clay worked great at removing bonded on contaminants but after I was done, I noticed my paint was marred. My paint is a little on the soft side (2012 G37 pearl white). The marring is on the light side and can only be seen in bright lights at certain angles.
    What is the fastest and easiest solution to remove the marring?
    Thank you.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,640
    66
    Re: Professional Mild Clay Marred my paint
    A cleaner wax or a light polish such as ultimate polish will remove the marring.
    Welcome to MOL.
    Apr 2014
    Sacramento
    3
    7
    Do you think Ultimate Polish by hand would be good enough?
    Jul 2013
    Lawndale, CA
    5,640
    66
    It should take care of it. Give it a shot on an area and see if it works.
    Registered Member Top Gear's Avatar
    Feb 2013
    Carolinas
    842
    17
    Claying is one of those things that's great in theory, but not so much in practice. The reason is conditions have to be perfect for every square inch clayed, and the contaminants themselves or a dry patch of clay or a piece of dust falling from the sky can create circular scratches and smears by hand, and all that has to be cleaned up - very counter-productive. Claying a whole vehicle is something I feel I can safely ignore for the rest of my life. However, I'll sometimes occasionally use clay for spot fixes as a first step, or use it on glass, where it works a slightly better.
    Instead, in your case, try a machine polisher with a mild combo, say UP on foam, running slow, and with mild pressure. If you've ever seen a big floor polisher/waxer in use in a store, it's the same idea. Move around a small section as the polish is worked in, and the contaminants are broken down and removed. It's a bit of work, sure, but nothing compared to claying by hand, and the result will be a polished and perfectly smooth surface. This assumes you have already given it a good wash. If this doesn't work for the marring, then step up to a compound instead. If that doesn't do it, then start again with MF pads instead of nerf foam. You really can't do this by hand - or, I should say, you can do it in theory, but in practice you will be hard-pressed to get a consistent result over the whole vehicle in a reasonable time, every time.
    So, there's a level of finish work where you just have to move to a machine, and you're probably right on that line. We all were at one time
    First Correction | Gallery
    Apr 2014
    Sacramento
    3
    7
    Thanks for the tips everyone. I ended up applying ultimate polish by hand and the marring is gone along with some swirls.
    Feb 2013
    Carolinas
    842
    17
    Glad to hear it was an easy fix
    Jul 2013
    Lawndale, CA
    5,640
    66
    Quote Originally Posted by rsinger23 View Post
    Glad to hear that.
  1. Difference between Pro C2000 Mild clay and the consumer smooth clay kit ?
    By thedoc46 in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: May 13th, 2015, 10:59 PM
  2. C2000 Professional Mild Detailing Clay
    By Eldorado2k in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Mar 4th, 2015, 08:04 AM
  3. White Wax marred my paint
    By Shawn T. in forum Detailing 101
    Last Post: Jul 7th, 2013, 08:16 AM
  4. Smooth Clay Vs. Mild Clay
    By dfrady in forum Detailing 101
    Last Post: Mar 1st, 2012, 06:43 PM
  5. white clay bar kit or mild blue clay
    By nicepackage in forum Detailing 101
    Last Post: Apr 12th, 2009, 04:16 AM
