Advice is Needed
Results 1 to 10 of 20
Thread: Advice is Needed
    Mar 2016
    Tbilisi, Georgia
    28
    5
    Advice is Needed
    Hi Guys,
    I have done the full detail on my dark blue BMW E 60 . Here are the steps that I have performed:
    1. Hand Washed with Meguiars Wash and Wax
    2. Clayed the whole car with Sonax Clay Bar
    3. Cleaned the paint with P21 S Shine enhancing Paintwork cleanser
    4. Applied two coats of Meguiars Ultimate Paste Wax. Second coat was applied after 24 hours
    5. As a last step, applied one coat of P 21 S Carnauba Wax
    O.k. That was a huge work and took around 3 days. Overall car looks great, but today I have noticed that there are some light scratches/light swirls and light water sports on some parts of the car (especially on hood) that are only visible in the sun. It made me totally disappointed, after such a hard work.
    Now, I need your advice how to proceed. I am kind of perfectionist when it comes to my car, so would like to correct that swirls and scratches.
    I have the following products: Ultimate Compound, Ultimate Polish, P21 S paintwork Cleanser, Ultimate Paste Wax and P21 S Carnauba Wax and work by hand.
    So, please, give me some recommendations on that
    I will try to upload the photos, just to show the result of my 3 day work. Unfortunately, the swirls/scratches and water spots could not been seen in these photos, but just to show you the general condition of paint.
    Mar 2016
    Tbilisi, Georgia
    28
    5
    Re: Advice is Needed
    Jun 2010
    746
    19
    My best guess is that the P21 just wasn't aggressive enough to completely handle all the defects you had. Obviously, it worked for most of the car, so you were close.
    Hoods are often the panel I choose when doing test spots to determine my pad and product choice, because the combination of a horizontal panel, influence of engine compartment heat and heading face-first into the elements usually means that any product/technique that works well on the hood will be just fine everywhere else. You've got everything you need at hand to fix it. No need to start all over. Just do some spot treatments on the areas and panels that need it. Inspect it closely and identify any areas that need more attention. Start with the Ultimate Polish and see if that gets you the desired results. If not, move up to the Ultimate compound for any spots that need it. Depending on the outcome, you may want to go over those areas again with the P21 or the UP to remove any possible hazing left by the UC. Then reapply your waxes to any areas you've disturbed.
    Let us know how it goes.
    Bill
    Mar 2016
    Tbilisi, Georgia
    28
    5
    Thanks Bill...Just to clarify: If the UP works, would I still need to go over with P21 S or just wax? And, if I need UC, which will be better as a follow up product: UP or P 21s? It seems to me that P 21 S is a lot easier to apply and buff off, than UP
    Thanks again !
    And the last issue: There are some water spots on the hood...Will be the products that I have just mentioned, fine for removing them?
    Jun 2010
    746
    19
    If the UP works for you, just go right to wax. If you need to go to UC, inspect the treated spots after treatment. Some paints have finished down well for me with UC, mainly GM harder clears, but some need another step. The only BMW I've spent time with was white and responded well to D151, so I've never tried anything stronger. Either the P21 or UP should work if you need a finish polish. Waterspots are tough to read, but follow the same process with a test of UP first and UC if needed.
    Bill
    BTW, I just checked your pics and your BMW looks pretty darn good!
    Mar 2016
    Tbilisi, Georgia
    28
    5
    Thanks Bill ! I will try as you advised...Will treat a part of the hood first...Will Post Before and After Pics
    Mar 2016
    Tbilisi, Georgia
    28
    5
    What about this product? I have discovered a bottle in my garage. Do you think it will be milder than UP?
    http://www.sonax.com/Products/Produc...x-2-Hybrid-NPT
    Quote Originally Posted by BillyJack View Post
    Bill
    Mar 2016
    Tbilisi, Georgia
    28
    5
    O.k
    I have tried a spot on the hood. First used UP...It definitely removed water spots and some of the swirls/scratches....Then went with UC...Frankly speaking, could not say that UC performed better than UP
    Here are some pics...Most damaged area when inspected closely is the back part of the trunk, around emblem...tried with UC, UP...but did not see any significant improvement...
    So, to conclude: I am more or less satisfied with UP as far as it made a part of the hood look better (removed water spots, some swirls/scratches)...As for the UC, I was expecting more...Maybe, I should compound first and than go with Polish to get better results? Just had not enough time to try....
    Is there any product that will just fill into this microscratches, so they are no more visible? Maybe some color polish will work?
    Or do I need I machine work done by professional? As I know UC and UP have far better results with machine polishers?
    Generally, when in the shade car looks nice, but sun makes things not the way I like to be....
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,508
    64
    Deeper defects are harder to remove by hand. A machine would do a better job.
    Feb 2017
    Philippines
    4
    Quote Originally Posted by Giorgi12 View Post
    Hey man. Let me know if Sonax did the trick. I want to try that product too.
  1. Bit of Advice needed
    By Paul K in forum Detailing 101
    Last Post: Jan 15th, 2016, 09:58 AM
  2. Much needed advice
    By rsum26 in forum Detailing 101
    Last Post: Aug 19th, 2010, 09:48 AM
  3. stocking up...advice needed
    By J.S. in forum Detailing 101
    Last Post: Jul 8th, 2009, 07:52 PM
  4. Advice Needed...
    By turbodreamer in forum Detailing 101
    Last Post: Feb 16th, 2005, 03:22 PM
  5. Advice Needed
    By jfwebber in forum Detailing 101
    Last Post: May 1st, 2004, 06:14 AM
