Wet sanded the plastic window of my soft top, now I can't get the scratches out.
Results 1 to 4 of 4
Thread: Wet sanded the plastic window of my soft top, now I can't get the scratches out.
    Dec 2007
    34
    I have a 2001 Honda S2000 with the rear plastic window. The window looks pretty terrible, super hazy and wrinkled. But, the rest of the top is in fantastic condition, and I can't justify replacing it just for the window.
    Just as my luck would have it, a raccoon got into my garage and walked all over my car. Luckily, it didn't damage it much, but it did put some deep scratches into the plastic window.
    I tried polishing them out with a DA polisher and PlastX, but it didn't touch them. They are fairly deep, so I didn't expect it to. I then wet-sanded the scratches with 1k, 2k, and then 3k paper until it was smooth.
    After that, I loaded up more PlastX onto a LakeCountry (sorry Meguiar's! I was out of pads :S ) orange light cutting pad and tried polishing out the haziness that the 3k paper left behind. I got about 30-40% of it out, but you can still see the haze. I repeated this 3 times and it never improved from there.
    What would you guys suggest I try next? I have most Meguiar's cutting/polishing compounds - Can I use M105 on the window? Should I buy another product? Appreciate any advice.
    Jun 2005
    The Real NorCal
    4,116
    145
    Re: Wet sanded the plastic window of my soft top, now I can't get the scratches out.
    Have you tried Plast-X on a non-compounding pad, such as maybe just a foam or microfiber hand applicator pad?
    Dec 2007
    34
    Quote Originally Posted by roushstage2 View Post
    I.have.not,.do.you.think.that.would.help.if.a.cutting.pad.couldn't.do.anything?.For.some.reason.my.spacebar.isn't.working.on.here..sorry.about.that..Works.everywhere.else?
    Jun 2005
    The Real NorCal
    4,116
    145
    It could possibly help. Worth a shot at this point I'd think. A cutting pad is made from a more aggressive type of foam vs. a regular foam applicator pad, and more so than a MF applicator pad.
  1. Scratches on Window Plastic Trims
    By tranxhdr in forum Detailing 101
    Last Post: Sep 6th, 2016, 09:50 AM
  2. yellowed vinyl / plastic window
    By gclark26 in forum Meguiar's Consumer Line Products
    Last Post: Sep 30th, 2014, 09:23 PM
  3. Swirls on Plastic Trim next to window ...
    By FIREdawg in forum Detailing 101
    Last Post: Feb 7th, 2012, 08:16 AM
  4. Clear Plastic & Vinyl Window Wax
    By Michael Stoops in forum Meguiar's Marine/RV/Flagship Lines
    Last Post: Jan 9th, 2012, 09:45 AM
  5. plastic window care
    By luckyinitaly in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: May 31st, 2009, 04:40 PM
