help with speed setting
Results 1 to 9 of 9
Thread: help with speed setting
    Apr 2017
    new jersey USA
    26
    5
    so i went to harbor freight and picked up the chicago electric dual action random orbit variable speed polisher the speed settings are numbered 1,2,3,4,5,6 it says 2000-6400 OPM. can someone help me I'm not sure what speed is needed for each application as in compounding..? polishing..? waxing..? buffing..? thank you guys for all your help
    Apr 2017
    new jersey USA
    26
    5
    Re: help with speed setting
    i have the 6 inch pads if it makes a difference
    Registered Member exploreco's Avatar
    May 2014
    Central IL
    677
    14
    I use between 5 and 6 for polishing and 2-3 when I use my Nanoskin Autoscruber Pad.
    2014 Toyota Venza - Attitude Black Metallic
    2010 Ford F150 Lariat 4x4 - Royal Red Metallic
    2006 Honda Odyssey EXL - Slate Green Metallic
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,895
    67
    8,963
    101
    Keep in mind that in addition to machine speed, arm speed, pressure, & size of working area are big variables in your overall results. The slower you move your arm & the more pressure you put down when using a compound or cleaner/polish, the more "cut" or "correction" you are going to obtain. Pad rotation is also important whether you are cutting or finishing. For a standard size stroke machine like our MT300, PC7424 or the harbor freight unit you have, we would suggest using our 5 Inch Soft Buff DA Foam Discs. 6 Inch are OK, but using a 5 inch pad in our opinion will allow to get the best cut & finishing ability out of your machine. More information on these discs if needed can be referenced at the following below link:
    Meguiar's Soft Buff DA Foam Discs
    800-854-8073 ext 3845
    Apr 2017
    new jersey USA
    26
    5
    i am getting a new backing plate and pads I'm getting 5 inch and 3 inch backing plates along with new pads
    Jul 2017
    Harpers Ferry, WV
    4
    I have had good results on black paint with the HF DA using 3 to spread the polish around then up to a 5 for rubbing in. I can’t not get swirl marks out on polishing but the wax afterwards seems to remove most swirls. After wax I follow up with detail spray. That removes all swirls. I hope with some experience I can remove swirl marks at the polish stage.
    1967 Buick GS 400. Triple Black Conv
    Jan 2007
    Rochester Hills, Michigan
    666
    21
    It totally depends...
    I just finish polished my gf's truck with a 1st gen Porter Cable 7424 on speed 1! I know a lot of people can't get that thing to spin unless It's on speed 5 or 6, but once you get some experience, and start experimenting you can get a feel of how capable the Meguiar's Super Micro Abrasive Technology actually is.
    On Monday I had a van. It was spur of the moment, and all they wanted was a cleaner wax. The front bumper was trashed so I went over it with Ultimate Compound and green pad on speed 3 - 3.5.... It took two or three passes, and came out great.
    I think sometimes we over shoot the target using high speeds, high pressure, etc. We end up exhausting the lubricants, and overloading our pads with liquids.... Back off the speed, pressure, and amount of product and see what happens. You might be surprised.
    This won't work as well with the traditional orange and white pads though. Use the pads I have in my profile pic, or the Meguiar's discs.
    Aug 2010
    Fairmont, MN
    77
    1,443
    25
    I agree!
    Sometimes, going low and slow will give ya results that one didn't think possible. Guess you could call it a 'surgeons touch' or doctors oath-"do no harm."
    Bill
  1. Setting up my own shop - What do I need?
    By agp423 in forum Detailing 101
    Last Post: Jun 23rd, 2009, 03:12 PM
  2. Speed setting for G110
    By RayS in forum Detailing 101
    Last Post: Jan 21st, 2009, 01:04 PM
  3. What should the speed setting be when using ScratchX?
    By 03mach1 in forum Machines - The Dual Action Polisher
    Last Post: Mar 25th, 2008, 12:46 PM
  4. speed setting
    By hipocket in forum Machines - The Dual Action Polisher
    Last Post: Feb 20th, 2008, 03:14 PM
  5. Speed setting for the PC
    By Razor88 in forum Detailing 101
    Last Post: Mar 25th, 2005, 07:57 PM
