Very fine scratch removal tips
Results 1 to 6 of 6
Thread: Very fine scratch removal tips
    May 2017
    springfield, il
    3
    3
    I have painted my mustang black single stage. Sprayed four fairly heavy coats. I have been using Wizards Turbo Cut followed by Wizards Finish Cut and then Wizards Shine Master. I started wet sanding with 1500, 2000, 2500, 3000 trizact and ended with 5000 trizact. Knowing that this is black I wanted all scratches out. However, when getting a closeup and looking for scratches I still can see the 2500 grit scratches. I want to continue to take them out but fear of getting too thin of paint scares me. I have never used Meguiars buffing and polishing products so what do some of you experts recommend for these 2500 grit scratches. I doubt the average person will see them but I do so that's why I am bothered. Note, when wet sanded and just before buffing there is no visible evidence of any flaws. Once buffed and polished I can see the scratches and a few remaining orange peel depressions. Thanks for any advice.
    May 2017
    springfield, il
    3
    3
    Re: Very fine scratch removal tips
    Sorry for the mis-leading thread name. It should of said that I was seeking tips. Too late to edit when I realized my mistake.
    Registered Member DasBurninator's Avatar
    Nov 2014
    Denver, CO
    459
    How are you wet sanding? By hand? Using a DA?
    What type of block are you using if by hand?
    If by DA, are you using a foam interfacing pad?
    I would reach for M101 or M100 to take care of stuff in the 2500 range. Both are great and have excellent work times. The M101 is going to be more aggressive and meant for foam pads. (works great on a DA with MF pads though).
    What machine and pads are you using for buffing?
    Sep 2008
    Sydney, Australia
    1,350
    25
    Not trying to ask a silly question here but how did you determine the scratches you're seeing are 2500 grit over all the other grit sizes you have used?
    May 2017
    springfield, il
    3
    3
    Quote Originally Posted by DasBurninator View Post
    I am sanding by hand with a variety set of Durablock pcs.
    Presta black and white twist wool , black finishing pad, and a white polishing pad.
    DeWalt rotary.
    As far as what grit I am still seeing I am assuming it's the 2500 grit as I work the 1500 grit one direction only then work the 2000 grit another direction only and finally the 2500 grit a different direction. Then Trizact 3000 the opposite direction and finishing up with Trizact 5000 in another. Before starting any buffing and polishing the paint looks like flawless glass. Once it starts to shine I can see the fine scratches that I am sure the Trizact did not leave. Thanks to all.
    Nov 2014
    Denver, CO
    459
    Quote Originally Posted by tgwise View Post
    DeWalt rotary.
    Are you letting your paper soak for 15 minutes or so before sanding?
    I generally find sanding blocks can be more aggressive and tend to prefer using a DA where possible.
    Are you sure the marks you see aren't from using a wool pad?
  1. Replies: 3
    Last Post: Jan 3rd, 2013, 08:59 PM
  2. Removal of Fine Sunlight-Only Scratches
    By NTL1991 in forum Detailing 101
    Last Post: Mar 22nd, 2012, 08:16 AM
  3. Help with first time swirl removal/scratch removal...
    By ilikepizza in forum Detailing 101
    Last Post: Apr 5th, 2007, 06:48 PM
  4. windshield fine scratch
    By voidmain in forum Detailing 101
    Last Post: Nov 22nd, 2006, 10:44 AM
  5. ultra fine swirls after scratch x and dc1
    By silversx in forum Detailing 101
    Last Post: Jul 7th, 2006, 04:04 PM
