Would there any problems of doing this? It should work the same as it does on paint and it would a long lasting protection, especially if your headlights have been recently restored or buffed. or would it affect the headlights? I just want to protect them, but I don't like the idea of putting a film on them. I figure the since is a sealant, it should last 3 months and it would repel grime, water spots, the sun, etc. Could the wax even if removed properly caused them to stain?
Would it be a good idea to use Meguiar ultimate liquid wax on headlights?
Re: Would it be a good idea to use Meguiar ultimate liquid wax on headlights?
It shouldn't be a problem, although Meguiar's has a sealant specially made for plastic headlights. As for the durability of Ultimate Wax vs. Meguiars Headlight Protectant, it would be safe to say that the Headlight Protectant will work better, since it is designed specifically for plastic headlights.
Originally posted by ffboy View PostIt shouldn't be a problem, although Meguiar's has a sealant specially made for plastic headlights. As for the durability of Ultimate Wax vs. Meguiars Headlight Protectant, it would be safe to say that the Headlight Protectant will work better, since it is designed specifically for plastic headlights.
Originally posted by Cogos View PostWould there any problems of doing this? It should work the same as it does on paint and it would a long lasting protection, especially if your headlights have been recently restored or buffed. or would it affect the headlights? I just want to protect them, but I don't like the idea of putting a film on them. I figure the since is a sealant, it should last 3 months and it would repel grime, water spots, the sun, etc. Could the wax even if removed properly caused them to stain?
You may not like the idea of film but it protects better than a sealant. Protects from the headlights yellowing as well as damage from road debris being flung at the car (aka road rash or pitting). I have my headlights covered with xpel film and won't look back.
Originally posted by Cogos View Postis discontinued
Ultimate Fast Finish, Wash Plus+, Basic Headlight Restoration Kit, Two Step Headlight Restoration Kit, Heavy Duty Headlight Restoration Kit, Keep Clear Headlight Coating, Perfect Clarity Glass Care Kit, Mirror Bright Vinyl & Rubber Treatment, Mirror Bright Polishing Wax Paste, Hot Rims Metal Polish, Hot Shine Reflect Foam, Dub Tire Foam, D166 Ultra Polishing Wax, 3" D/A Microfiber Discs,
Or pick up the aerosol coating. Just be sure to mask the area to protect yourself from overspray. Same form of protection as the heavy duty kit but in aerosol form.
Ultimate is OK to use for headlights & tail lights, but like others have said, we have products designed specifically for this task which will perform better. Out latest offering for this is Meguiar's Keep Clear Headlight Coating. More information can be referenced at the following below link:
Meguiar's Keep Clear Headlight Coating - Product Introduction Thread
Using Meguiar's G17804 Keep Clear Headlight Coating
