Gunk engine brite
  • Gunk engine brite
    This question my be redundant but what do most of you use to clean an engine....Gunk engine brite or Purple power degreaser..
    Re: Gunk engine brite
    Staining happened when I cleaned my engine compartment with Purple Power.
    Others I know have mentioned similar difficulties.
    I still have some fogging on parts of my polished aluminum valve covers that I have not been able to polish bright.
    I moved it away from my detail products.
    Directions on their bottle: 1) Test an out-of-site area to determine surface acceptance and colorfastness to avoid damaging surfaces, especially aluminum, painted surfaces and fabrics.
    From my experience with it, I added a large hand printed label to my bottle. It reads:
    "Do Not Use Near Finished Metal"
    "Rinse Thoroughly"
    "Not For Engine Use"
    I marked other side of bottle:
    "Caution. Ruins Aluminum Finishes"
    It likely will not be used a second time in my engine compartment. Possibly to clean the rear end or trans (not the aluminum trans pan). Maybe to clean parts before repainting them (not as a paint prep).
      I should point out that unlike many 2017 engine compartments, the avatar to the left shows an engine having many aluminium components.
      Their warning is on the label. My extra labels are to get me to read them.
        I'm driving a 2002 Rodeo I doubt there's any or alot of aluminum..so you'd say go with Engine brite
          One of the worse things about Gunk is that the smell seems to last forever. Does it work-yea, but if you can get by using something much less 'potent' I'd try that first.
          As said above, MANY 'engine cleaners' will attack anything aluminum, so use with caution.
          I'll just add this, as someone who hates to work on a dirty engine I get by just using an APC once a year.
          Bill
