What are your favorite Detail Tools under $1
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: What are your favorite Detail Tools under $1
    Dec 2015
    San Juan Capistrano CA
    694
    What are your favorite detailing tools under $1
    This thread is meant to share ideas on detailing. Frequently there are common very inexpensive tools that we can adapt to help with detailing.
    Add your ideas to the thread.
    Dec 2015
    694
    Re: What are your favorite Detail Tools under $1
    I'll start with Q-Tips. I buy a small supply and transfer them to a clear plastic box to keep them clean until used.
    Examples of using them for automotive detailing include:
    Cleaning in hard to reach small places like around the lug nuts.
    Dipped in an appropriate solvent, they can help remove dried fuel lacquer from a carb leak.
    Well, That's not nice. The images said they uploaded to my Gallery, yet are not there to use.
    I will try an alternative.
    Dec 2015
    694
    I find these small cotton squares useful in the engine compartment.
    Particularly on small bright metal pieces.
    I have found them effective on the following:
    Applying solvent to remove dried fuel that leaked from carb (be careful the correct solvents on aluminium).
    Using a mild metal cleaner on aluminum lines, or shiny nuts/bolts.
    Dec 2015
    694
    I found the sponge wedges useful in the engine compartment getting into tight spaces.
    They also fit A/C outlets pretty well.
    Dec 2015
    694
    A detailing forum pointed me to an article on washing microfiber towels. The presenter described a number of good ideas. He grades his towels based on condition and cleanliness. I don't do high volume detailing, so these small containers work well for me.
    I found these clear containers at a buck and under store. I could buy them with different color tops as a visual queue for the grade. I then applied computer address labels to help me if I forgot the colors.
    My grades are set up as follows:
    Note: Sewn in tags must be removed prior to placing into a container!
    A Green top Very clean and in very good condition - Use for paint
    B Blue top Clean fair condition - Use for glass and buff metal
    C Purple top Washed, yet may still hold some dirt in fibers - Use for interiors and wheels
    D Red top Washed, yet probably last use on car - Use for under carriage etc. or as a last use to wax wood furniture in home.
    I keep a couple of containers for each grade. With this smaller size container, I can drop a grade A and grade C container into the truck when going to a car show.
    Dec 2015
    694
    It is important to pull the sewn in tags and threads off your microfiber towels.
    I use a larger $0.99 clear container to hold new towels.
    When I bring new microfiber towels homes, I pull the tags and then put them into the clear containers.
    The larger size lets me know the included towels are new, tag removed towels.
    I can stack the smaller containers on the larger ones on my detailing cart. The cart is a recycled 3 shelf audio/video cart on wheels.
    Dec 2015
    694
    I use 1 gallon freezer bags with a place to write contents to hold my soiled microfiber towels.
    This helps keep them from collecting dust and debree before being washed.
    I leave the end unsealed, to allow them to air dry vs. potentially mildewing.
    Some folks segregate by towel grade and/or by chemicals used.
    My usage is not heavy enough for that, so I wash together (twice with Tide).
    I inspect both sides and grade (A, B, C or D) again as I put them into the clear boxes holding the graded towels.
    Dec 2015
    694
    If your amount of towels exceeds mine for just my vehicles, check Ammo NYC video.
    https://www.youtube.com/watch?v=X9W-mMJicSM
    Nov 2010
    Vancouver
    1,218
    22
    At the dollar stores I have found various brushes to clean my interiors, they could be skinny paint brushes, makeup brushes (what my wife uses). These can really get into the nooks and crannies of car vents, interior trim, etc.
    I have also found small measuring spoons/cups to help mix my wash soaps perfectly....I hate using the soap bottle cap as a measurement tool...
    "STRIFE" aka Phil
    Dec 2015
    694
    Meguiar's Online Member BillyJack suggest:
    To remove wax buildup on those tricky areas around emblems and moldings, grab a package of bamboo skewers at the supermarket or dollar store. Spending a buck or two gets you a lifetime supply.
    You can wrap a microfiber towel or one of the cotton squares above to reduce chances of scratching the paint.
    https://cdnimg.webstaurantstore.com/...120/590715.jpg
    Sharing them with the cook has benefits too.
  1. What's your favorite wheel cleaning products / tools?
    By CreamPuff in forum Detailing 101
    Last Post: Aug 9th, 2012, 12:35 PM
  2. which tools?
    By mcd in forum Detailing 101
    Last Post: Dec 21st, 2009, 09:04 AM
  3. What's Your Favorite Car to Detail?
    By BigLouie in forum The Break Room
    Last Post: Oct 2nd, 2009, 06:51 AM
  4. Engine detail, my favorite kind of detailing!
    By Ash Erickson in forum Show Off Your Latest Detail Work
    Last Post: Apr 4th, 2007, 04:34 AM
  5. Help for Show Detail and show tools for a Noob
    By punx77 in forum Detailing 101
    Last Post: Jun 13th, 2005, 10:16 AM
