Removing these swirl marks
Results 1 to 8 of 8
Thread: Removing these swirl marks
    Apr 2016
    Kenosha, Wisconsin
    35
    5
    Hey guys!
    So, I just picked up a 2018 Mazda CX-5. I love it, but I keep getting swirl marks on the shinny I think painted B-Pillars). What can I use on these to remove them? Would megs x 2.0 hurt them if they
    8,312
    94
    Re: Removing these swirl marks
    Quote Originally Posted by JMan136 View Post
    Hey guys!
    Congrats on the new car! These shiny painted B Pillars are THE most delicate & softest paint surface we might be able to imagine! You are OK to use our cleaners & compounds for automotive paint on them, but we would recommend using the least aggressive process needed. For example,
    Wipe off dust gently with our Quik Detailer Mist & Wipe Spray and a quality microfiber towel like our Supreme Shine Microfiber Towel/
    Start with Ultimate Polish Pre-Waxing Glaze, applied with a soft foam applicator pad (if working by hand). Keep your hand flat, applying in circular motions with light to moderate pressure. The product should break down to a light wet film which you will want to wipe off immediately while it is still wet. Check your results with good lighting.
    If the above combination does not work to remove the defects to your satisfaction, you could move up to Scratch X 2.0 or Ultimate Compound, both are more aggressive. Apply in same manner than above, and check your results. Don't be surprised if this combination hazes the paint, or in other words makes the paint look gray. The paint is typically so soft that cleaners can not leave the best finish behind. This is where Ultimate Polish comes into play again, you may have to do 2 - 3 applications of Ultimate Polish to bring back the clarity of the painted B Pillar.
    Apply your favorite coat of wax/sealant afterwards for protection.
    We have heard of many users "correcting" these b pillars as perfect as they can get, and then having clear paint protective film installed.
    Hope this helps!
    800-854-8073 ext 3845
    Jan 2007
    Rochester Hills, Michigan
    613
    20
    I've had great luck with Ultimate Polish to take care of pillars.
    Apr 2016
    Kenosha, Wisconsin
    35
    5
    Quote Originally Posted by drumdan View Post
    How many passes do you need to make usuallly?
    do they come back after you wash the car?
    Jan 2007
    613
    20
    Usually two or three light passes at speed 4.
    No the scratches Don't come back for me.
    Apr 2016
    Kenosha, Wisconsin
    35
    5
    Do you think Ultimate Polish on a yellow foam pad by hand would remove them, or just make it worse
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    41
    5,531
    64
    Depends on how deep they are. The limitation is the hand. A foam pad with ultimate polish is a good starting point to make them look better.
    Jan 2007
    613
    20
    I agree!
  1. Trouble removing scratches/swirl marks
    By tiebar90 in forum Detailing 101
    Last Post: Apr 19th, 2016, 06:56 AM
  2. Trouble removing scratches/swirl marks
    Last Post: Apr 17th, 2016, 06:31 AM
  3. Removing surface swirl marks from Black 08 Fusion
    By Redbirded in forum Detailing 101
    Last Post: Nov 26th, 2009, 05:13 PM
  4. Appreciate advice on removing swirl marks
    By tomb13 in forum Detailing 101
    Last Post: Jan 31st, 2007, 02:55 PM
  5. Removing swirl marks- DC1 necessary?
    By technik in forum Detailing 101
    Last Post: Sep 6th, 2006, 05:22 AM
