2018 ceramic coating concensus?
Results 1 to 10 of 14
Thread: 2018 ceramic coating concensus?
    Registered Member Palantirion's Avatar
    Apr 2010
    CA, USA
    6
    9
    I did some searching but didn't find a lot on the topic here. What do you guys think about ceramic coatings now that they have been on the market long enough to exceed their claimed lifespans?
    My initial concerns are:
    1) I keep my cars a long time, so I want the ability to work on future defects. Ceramic effectively prevents this. Althogh ceramic claims it prevents the defects in the first place.
    2) If you have to replace a panel after a collision how does the body shop match the color exactly? And how could they color blend over ceramic-treated panels?
    3) I have read it must be sanded off to be removed. Thus reducing the factory clearcoat, correct? On a collector car with original paint that could be a big turn-off.
    Aside from the above: Does it work as well as advertised? and for as long? The top coats seem a lot like the same labor as waxing your car in a conventional sense, so where is the ceramic maintainence advantage?
    Appreciate your responses.
    www.ebsart.com
    2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior
    -for details: www.mymcoupe.com
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    39
    5,349
    60
    Re: 2018 ceramic coating concensus?
    Quote Originally Posted by Palantirion View Post
    There is a lot of information over on Autogeek and Autopia with regards to coatings. In short coatings are not the end all be all. They still require maintenance.
    Coatings are not scratch proof and are still susceptible to swirls. Proper washing techniques are important to limit any wash induced marring. As marring is still going to happen.
    Coatings have the benefit of the self cleaning effect which will make washing easier. Coatings still get contaminated and require a different method of decontamination in chemical rather than mechanical (clay).
    Manufactures claim the durability in years. For the most part coatings will outlast a wax or sealant. But like a wax or sealant, the durability of a coating is going to be affected by the environment it is exposed to. For example someone will experience longer durability in California compared to someone who lives in the harsh winter climates.
    A consumer grade coating can and will be removed with abrasion. Such as an abrasive polish. They form a thin layer, yet a thicker layer than a wax or sealant. Mention it to the body shop or prep the panels before the vehicle is dropped off.
    Again most consumer grade coatings can be removed with abrasion. There are professional level coatings that require sanding but not all of them.
    Coatings work as advertised as long as one goes in knowing their pros and cons. The prep is more labor intensive. The durability is going to vary based on the environment it is exposed to and how well it is maintained.
    Head over to the other forms as I just gave you the short version and there are many more of us there who use coatings. You won't find may here as Meguiar's does not sell a coating in the US market.
    Jan 2007
    Rochester Hills, Michigan
    537
    18
    The people I work for, have me maintain their cars annually, or bi-annually. I must have over sold them on the polymer that they don't even care to try the coating.
    I have some, just haven't used it yet...
    Jun 2018
    North Carolina
    57
    Call me crazy but i actually enjoy the polishing and waxing aspect of maintaining my vehicle, plus i have too many Meg's products that would go to waste should i elect to go Ceramic.
    Feb 2016
    AZ
    42
    3
    I'm getting a new car soon. I love using Meguiar's ULW on my cars. The surface is smooth & slippery & it is easy to apply & looks great to me.
    I have SunTEK PPF on the hood, bumper, front fenders & mirror backs & the ULW works just as well on that PPF.
    As I shop around Phoenix, Scottsdale AZ for a shop to apply PPF to my new car when it arrives, everyone wants to sell me a ceramic coating to be applied on top of the PPF. Very expensive. > $1,000. I've read the claims that it "repels dust" which is hard to believe. Also, it must be re-applied ~every 3 years.
    It just does not seem to be that much better vs. me doing the ULW. Other than lasting longer between applications will it "repel" dust better than ULW?
    It is dusty out here & there is often a fine layer of dust on my cars that I can mostly remove using California Car Duster between washes.
    I alway clay my car b4 using ULW.
    Jul 2013
    Lawndale, CA
    39
    5,349
    60
    Quote Originally Posted by Iconoclast View Post
    If you like using ULW and it works for you then keep on using it. Nothing wrong with it. In general a coating is going to look cleaner longer than a wax or sealant. If one lives in a very dusty environment then it does not really matter.
    Feb 2016
    AZ
    42
    3
    So, do you think dust will stick to ULW surface more than dust sticks to ceramic coated surface?
    For example, 1 month after application.
    Jul 2013
    Lawndale, CA
    39
    5,349
    60
    Hard to really say. A coating is not a miracle product. My cars are all ceramic coated and I haven't used ULW in a long time. It is good but for me the protection of a ceramic coating is what I was looking for. The ease of maintenance is another thing as well as staying cleaner longer and and having a better self cleaning effect. ULW is a great sealant and does a good job.
    Another thing to consider is fighting dust is a losing battle. I learned that a long time ago. It does get dusty here in So Cal and I end up washing weekly without worrying about dust during the week. I choose to not risk touching the paint more than I need to so that I avoid swirls and what not.
    If you are one that likes applying a wax or sealant on a regular basis then coating may not be for you.
    Registered Member snozan's Avatar
    Jul 2016
    Sweden
    41
    154
    4
    I always like to post this when it comes to ceramic coatings:
    Feb 2016
    AZ
    42
    3
    "Staying Clean longer"
    How vs. Sealant?
    Thanks!
  1. Water spots on my ceramic coating, removed?
    By akgolfpro in forum Detailing 101
    Last Post: Mar 8th, 2018, 07:38 AM
  2. Replies: 3
    Last Post: Sep 30th, 2017, 08:24 PM
  3. Supere Ceramic Coating
    By Blumax1 in forum The Break Room
    Last Post: Aug 27th, 2017, 07:04 AM
  4. Sonax CC36 ceramic coating, anyone tried it?
    By amblin83 in forum The Break Room
    Last Post: Jun 18th, 2017, 06:13 PM
  5. FS Duragloss Enviroshield Ceramic Coating System
    By The Guz in forum For Sale or Trade
    Last Post: Sep 9th, 2014, 11:45 PM
