Will this work???
Results 1 to 3 of 3
Thread: Will this work???
    Registered Member GLOCKer's Avatar
    Aug 2014
    ATL, GA
    307
    9
    Will this work???
    I've been working on fixing up a 1998 Ford Explorer and it's almost time to start tackling the exterior. Today I just grabbed a bottle of ScratchX to assess what I am going to have to tackle with the paint.
    So here is a test spot where I knocked off the pin-stripe decal. You can see that the sun has baked the stripe into the paint AND I screwed up with the rubber wheel stripping that pin-stripe and dug into the paint a little. I think I'm going to have to hit these areas with nicks with touch-up paint and wet sand them before attempting the paint correction.
    This; towards the leading edge of the hood there is basically a line of messed up paint. This was caused by the sun/wind deflector that was on the front of the hood and filled with dirt and debris for, at the least, the past four years. I'm thinking of sanding this back to clean it up, hitting it with spray touch-up paint, and wet sanding it to blend into the hood better. I know it wont be perfect, but if it looks horrible I'll just put the sun/wind deflector back on the hood!
    Will this work? Will I need to prime before spraying on something like DupliColor's matched spray paint?
    2014 Mustang GT 6-Speed Manual
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    5,577
    65
    Re: Will this work???
    Before going right to sanding do a test spot with a compound and cutting pad on a DA and see if that does anything.
    Aug 2014
    ATL, GA
    307
    9
    10-4!
    At the edges of the hood it's right through to bare metal in small spots.
  1. Do you guaranty your work? My work is "superbly guaranteed"
    By Detailing by M in forum Detailing 4 Dollars
    Last Post: May 31st, 2013, 12:57 PM
  2. A day off of work
    By Wolf-Strong in forum Detailing 101
    Last Post: Oct 28th, 2008, 10:10 AM
  3. Will #80 work for me?
    By Jeepster04 in forum Detailing 101
    Last Post: Sep 27th, 2006, 05:21 PM
  4. Would this work...
    By 96Lude in forum Detailing 101
    Last Post: Jun 28th, 2006, 10:56 AM
  5. How to work #9
    By NVCobra in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Oct 11th, 2004, 04:50 PM
