Question about Meguiar's Keep Clear Headlight Coating - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Question about Meguiar's Keep Clear Headlight Coating
  1. #11
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    8,181
    Rep Power
    92
    Re: Question about Meguiar's Keep Clear Headlight Coating
    Quote Originally Posted by GaryODS View Post
    Thanx for your prompt response. I need a little clarification, if say 6 months after cleaning with Plastx and coating my headlights with Keep Clear the headlights aren't as clear and bright as I like them, should I avoid using Plastx because it's abrasive? Is there another product to spiff them up instead of Plastx you recommend
    PlastX Clear Plastic Cleaner & Polish is used on an as needed basis to remove light oxidation from headlights & increase clarity/gloss. You do not need to avoid using it, it is just not ideal to use on a light which has our Keep Clear Headlight Coating on it. If you have a light which has a coat of our Keep Clear Headlight Coating on it, & you want to apply another coat 6 months down the road, it would be OK to just re-apply another coat on a clean & dry, properly taped off light. If you want to use a mild polish like PlastX, it would be ideal to remove the Keep Clear Headlight Coating, either with multiple applications of PlastX or by using 91% isopropyl alcohol a few times.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  2. #12
    Registered Member
    Join Date
    May 2006
    Location
    Suburban Washington DC
    Posts
    179
    Rep Power
    15
    I recently re-cleaned my headlights and applied Keep Clear coating. The passenger side came out very nice but the driver side wasn't good sort of blotchy.
    How did you clean them? If you polished them super smooth, you might have a problem. Clearcoats need a tooth to adhere to properly.
  3. #13
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    8,181
    Rep Power
    92
    Quote Originally Posted by atikovi View Post
    This product is not a clear coat paint. It does not require a scuffed or sanded surface for proper adhesion.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
  4. #14
    Registered Member
    Join Date
    May 2006
    Location
    Posts
    179
    Rep Power
    15
    OK, I was going by what the 3M product I use says to do.
  5. #15
    Registered Member
    Join Date
    Jan 2020
    Location
    Raleigh, NC
    Posts
    1
    Rep Power
    1
    We also use Plastx when we restore our headlights for our customers. Its a great product and we will continue to use it.
    Neal
    Raleigh, NC
Thread Information
Users Browsing this Thread
Similar Threads
  1. Using Meguiar's G17804 Keep Clear Headlight Coating
    By Nick Winn in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jan 8th, 2020, 10:38 AM
  2. Prep for Keep clear headlight coating?
    By SLM in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jul 2nd, 2019, 08:11 AM
  3. Meguiar's Keep Clear Headlight Coating
    By Meguiar's Inc. in forum Meguiar's Product Introduction Threads
    Last Post: Oct 29th, 2018, 04:40 PM
  4. Using Meguiar's G2980 Heavy Duty Headlight Restoration Kit w/new wipe on coating
    Last Post: Oct 15th, 2018, 06:28 AM
  5. Restore Headlights - Meguiar's Headlight Restoration Kit question I need info on
    By thehulk2002 in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jun 27th, 2012, 09:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
