I read this on a forum and now I'm hesitant to use it
Coatings" do little or nothing either (well, other than drain your wallet.)
McGuires makes a decent product that works; just be darn sure you don't get it on the paint around the headlamps as it will remove or severely damage the clearcoat too just like it does the hazed plastic on the headlamp! The best option, assuming it can be done with a reasonable amount of work, is to remove the headlamp from the vehicle -- that way you can't accidentally damage the paint.
And yes, it's only good for a year or so, and you get to keep doing it right up until you remove enough material that you wind up having to replace the headlight anyway.
