Looking for garden hose filter to reduce water spots when washing cars. Suggestions?
Results 1 to 9 of 9
Thread: Looking for garden hose filter to reduce water spots when washing cars. Suggestions?
  1. #1
    Registered Member
    Join Date
    Jun 2018
    Location
    Northeast PA
    Posts
    1
    Rep Power
    1
    Does anyone use an in-line filter on their garden hose when they wash vehicles? I'm looking to purchase one so I can reduce water spots, contaminants, metals, etc.
    Thanks in advance,
    TJ (NEPA_Wrangler)
  2. #2
    Registered Member Blueline's Avatar
    Join Date
    Apr 2007
    Location
    US
    Posts
    1,068
    Rep Power
    22
    Re: Looking for garden hose filter to reduce water spots when washing cars. Suggestio
    I used to use an in line cartridge type filter with a special cartridge to take out minerals, etc. It was (and still is) mounted to the wall in the garage. It did an okay job, but was a pain to attach the garden hose to it for input, and then a separate hose for the output. Each month the cartridge had to be soaked over night in salt...basically it was an inline water softener. Used it a few times, and then thought it might not be good to rinse the car in slightly salty water. Stopped using it, and bought myself an electric leaf blower, and use it instead. Works better, less hassle, no spots, and no monthly soaking of the cartridge.
  3. #3
    Detailing BoZo jfelbab's Avatar
    Join Date
    Apr 2004
    Location
    Cape Coral, FL
    Posts
    1,482
    Rep Power
    29
    Beside low pressure flowing the water off the car in sheets, I also use a leaf blower and I use UQD as a drying agent. Never any water spots on my cars.
  4. #4
    Registered Member NextLevelDetailAZ's Avatar
    Join Date
    Dec 2015
    Location
    Phoenix
    Posts
    8
    Rep Power
    3
    the filter i use and highly recomend at this link
    http://www.amazon.com/shop/thisisdetailing
  5. #5
    Wheel & Tire Moderator evo77's Avatar
    Join Date
    Aug 2004
    Age
    41
    Posts
    149
    Rep Power
    16
    Using a leaf blower or sheeting water with a garden hose only helps if you do it within seconds/minutes after fully rinsing the entire vehicle. It also depends on the level of water hardness in your area. Perhaps this works for those with lower hardness levels.
    Although I have never tested mine I can say that I have medium grade hardness. My vehicles are outside 24-7. Exposed to full sun nearly all day. So the paint is pretty dang hot before I even begin washing. Within seconds, water will evaporate and start etching. And although I can usually remove most of the spots with a quality brand QD spray while I'm drying, it takes extra effort and time to remove the stubborn ones.
    I just picked up this filter system out based on some good reviews (and a few youtube videos) showing that it does a pretty decent job at minimizing water spotting. I had to buy some fittings today so hopefully I can give it shot. Its 97 degrees right now!
  6. #6
    Join Date
    Apr 2007
    Location
    US
    Posts
    1,068
    Rep Power
    22
    Quote Originally Posted by evo77 View Post
    I realize you don't have the option, but I would never wash my cars in the sun. Not sure how good it is to splash cold water on a car that could fry eggs. The thermal contraction cannot be good. Like you, the water would evaporate leaving spots from our very hard well water. Fortunately, my two cars are garaged, and i can pull them out and wash under a large shade tree. Water sheeting and a leaf blower works extremely well for me, and it does not have to be done in seconds or minutes. If one can wash in the shade, it is the only way to go.
  7. #7
    Join Date
    Apr 2004
    Location
    Cape Coral, FL
    Posts
    1,482
    Rep Power
    29
    No shade here so I wash in the early morning or at dusk and only if my paint is cool to the touch. Sometimes it is difficult to share the driveway with all the mosquitos who are always active at those times.
  8. #8
    Registered Member
    Join Date
    Mar 2018
    Location
    Yankton South Dakota
    Posts
    3
    Rep Power
    1
    I just picked up one from Walmart today at the RV section in automotive. 1 filter and adapter for hooking up to water outlet for under $20.00. Hot today when I washed my car, but I spray quick detailer on each section before I dry. No water spots noticed. Can't tell if filter actually gave any benefits, but I sure felt better about it....
  9. #9
    Join Date
    Aug 2004
    Age
    41
    Posts
    149
    Rep Power
    16
    I want to report back with my experience with the amazon water filter kit I linked in my previous post.
    I just finished washing the family minivan. Direct sun and with the heat index it's 94 degrees! I am glad to report ZERO water spots! That's right, none! I will say this though, it takes a few gallons for the filter system to break in. The first time I used it I got a little water spotting but decided to give it one more go and I'm pretty happy with the results.
    It's a great bargain compared to other systems. I would recommend this to others looking for a solution to sun washing because shade or waiting until morning/evening is not available or convenient.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Reducing water spots with water filter
    By EPHIOS in forum Hot Topics & Frequently Asked Questions
    Last Post: Aug 10th, 2010, 11:24 AM
  2. Replies: 7
    Last Post: Sep 9th, 2009, 12:02 AM
  3. Replies: 30
    Last Post: Apr 3rd, 2007, 04:16 PM
  4. Portable....garden hose...?
    By CELL in forum Detailing for dollars
    Last Post: Mar 31st, 2006, 01:42 PM
  5. Replies: 1
    Last Post: Jun 9th, 2004, 07:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
