Help, How to Remove M105 Dust - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Help, How to Remove M105 Dust
  1. #11
    Registered Member Old Bear's Avatar
    Join Date
    Dec 2015
    Location
    San Juan Capistrano CA
    Posts
    643
    Rep Power
    11
    Re: Help, How to Remove M105 Dust
    DISO = Dealer Installed Swirl Options
    They are starting to come standard on most new cars.
  2. #12
    Join Date
    Dec 2015
    Location
    Posts
    643
    Rep Power
    11
    It might be good to try to flush the joints out some before using M205.
    My thoughts include M105 and M205 use SMAT Technology.
    I am not sure if the "particles" are the same size as in M105 only fewer or if they are smaller in M205.
    If M205 has smaller SMAT particles, I would not want to contaminate with larger particles.
  3. #13
    Registered Member Stephan's Avatar
    Join Date
    May 2013
    Location
    The Palm Beaches FL USA
    Posts
    426
    Rep Power
    11
    I know the DISO, thats how I found Meguiars years ago These are bad scratches, see area in photo 1 top left (and near top right) of fluorescent lite reflection on black paint. Pic 2 shows the white specs on door handle and above (not to mention door and hood, et al).[IMG][/IMG]
    [IMG][/IMG]
    2018 Acura RLX Tech - Majestic Black Pearl
  4. #14
    Join Date
    Dec 2015
    Location
    Posts
    643
    Rep Power
    11
    Ouch, Hard to tell from images, yet the scratches look deep.
  5. #15
    Join Date
    Jan 2007
    Location
    Rochester Hills, Michigan
    Posts
    608
    Rep Power
    20
    Quote Originally Posted by Stephan View Post
    Thanks for you suggestions Dan, hot as balls here in Southern FL today. Between errands, picking up some UC at Adv Auto, etc., I haven't tested the clay yet. I splattered/dusted M105 from the roof by the moon roof. I've only clayed the roof so far (before the M105), and only have bad scratches up there so M205 should take me home after claying the rest of the car. I will do a clay test tommorow, but the car has that Xillon **** on it from the dealer, so until I fix the scratches with M105 or UC, I'm not going clay crazy. GONNA WORK MY WAY DOWN FROM TOP TO BOTTOM with clay and 205 after fixing the bad spots from crappy dealer washing practices.
    I greatly appreciate your help, in spite of >90 views your were the only responses I received as of this writing.
    Stephan
    Sounds like a good plan of attack.
    Here in MI I had two jobs in the 90 degree heat myself, and it wasn't as much fun as usual.
    Always a pleasure to help.
  6. #16
    Join Date
    Jan 2007
    Location
    Posts
    608
    Rep Power
    20
    I tested a couple spots (side view mirror and arm and small spot at top of door) and it comes off easy with clay. Since I have to clay the whole car anywho, after I fix the bad scratch spots, should be golden. Didn't want to M105 large parts of the car that don't need M105. The whole car needs clay and M205, was in lot for 3 months the best I can tell and was treated like ****.
    Car is "new", 8 miles on odometer, but was washed by morons. They coated the car with filler wax or whatever and I didn't find errors for a week *^$#%!!!
    You are my hero of the day!
    Good!
    M105 is loaded with abrasives, which attributes to it's tremendous cutting strength, so when it dries, there are a lot of solids left over.
  7. #17
    Join Date
    Jan 2007
    Location
    Posts
    608
    Rep Power
    20
    Quote Originally Posted by Old Bear View Post
    Stephan
    I would have posted this earlier, yet I see you are not new to the forums. You have a higher Rep Power than I.
    Yet you used this phrase "I splattered/dusted M105 from the roof by the moon roof."
    Just double checking that you are not starting the DA while it is lifted above the surface. The rotation of the pad can then cause sling of larger drops of the product.
    Some times, we hold off posting if we see someone like DrumDan picks up a thread. Working one on one, can frequently get to results faster and with less diversion.
    I am adding to DrumDan's Rep for his good help with you on this thread.
    Thanks, Old Heat!
    The more the merrier for me, especially with someone as helpful and knowledgeable as your self.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 3
    Last Post: Apr 8th, 2015, 05:17 AM
  2. how to remove brake dust barrier?
    By MasterShake in forum Meguiar's Consumer Line Products
    Last Post: Jul 27th, 2012, 02:25 PM
  3. Please help, why am I getting so much dust with M105?
    By tt061880 in forum Detailing 101
    Last Post: Feb 22nd, 2009, 07:36 PM
  4. How to remove dust of #80 & #85
    By qewani in forum Meguiar's Consumer Line Products
    Last Post: Jan 2nd, 2009, 05:52 PM
  5. how to remove dust
    By mdkrusemark in forum Detailing 101
    Last Post: Feb 28th, 2007, 04:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
