Help!!! tar spot removal white paint - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: Help!!! tar spot removal white paint
  1. #11
    Jun 2016
    Oregon
    64
    3
    Re: Help!!! tar spot removal white paint
    Quote Originally Posted by BillE View Post
    I have never had a problem using kerosene. BUT that doesn't mean there couldn't be, but I really doubt any problem will show up. Just try a small area first to see how it performs. Using kerosene is a perfect examble of "like removing like". It is actually a solvent for many tar based product during production. Kero is really a pretty benign petro-just stinks to high heaven!
    I will add, living where 'they' use a lot of seal-coat, no matter have carefully one drives, ya just can't NOT get the stuff on your vehicle. Hence, I've always just grabbed the kero jug.
    Sorry to hear that Tarminator didn't work.
    Bill
    I tried Kerosene last night, granted it was a old jug (which I don't know if it has anything to do with it) but it didn't take them off, maybe helped a little. I didn't sit it there for a while, should I hold a rag on it for a longer time I did about a minute?
    I also used lacquer thinner, that seemed to work about as well as the kerosene but didn't remove them.
    I was thinking about getting some Trix by Carpros but I don't see a point in buying any other tar removers as I dont see anything being much better than Kerosene or thinner...
  2. #12
    Registered Member Purple Towel Detailing's Avatar
    Sep 2015
    Aurora, Illinois
    21
    3
    I had some road tar on a customer's car that did not come off with ANYTHING in my usual bag of tricks, including Tarminator, kerosene and gasoline.
    The only thing that worked was Goof-Off.
    I'm guessing that it isn't tar, but some type of road sealant or blacktop.
    Purple Towel Auto Detailing
    @purpletoweldetailing
  3. #13
    Jun 2016
    Oregon
    64
    3
    Quote Originally Posted by Purple Towel Detailing View Post
    I guess so, goo-off didnt touch it however I used the "automotive" gel style so its not the traditional in the can style... I was thinking maybe pb blaster? I have not tried that one. I will get some traditional goo off but I dont see that being better than just straight thinner.
  4. #14
    Sep 2015
    Aurora, Illinois
    21
    3
    Not Goo-Gone, try Goof-Off. Very different product and not available in a gel. It's a paint remover and can be found in the paint isle at Home Depot.
  5. #15
    Jun 2016
    Oregon
    64
    3
    Oh very interesting I will try that tonight! lets cross our fingers I can't compound over and over again
  6. #16
    Jun 2016
    Oregon
    64
    3
    I will obviously try a test spot in a location that can't be seen but how safe is this for Painted plastics on a car? the spots I am trying to remove are painted moldings around the wheel wells (all factory paint)? I bought some today from Home Depot and it says its for Asphalt and tar ( the pro strength stuff) I dont want it to melt the plastic.
  7. #17
    Sep 2015
    Aurora, Illinois
    21
    3
    It would have to eat through the clearcoat, the paint and the primer to affect the plastic in any way (it can't go through the paint to only harm the plastic base). I've used it before on different finishes and it works fine without harming the clearcoat. You will strip EVERYTHING off of the paint, though, so be sure to put some wax down when you're done to protect everything.
  8. #18
    Jun 2016
    Oregon
    64
    3
    Good news it didn
  9. #19
    Jun 2016
    Oregon
    64
    3
    And I forgot about the punctuation
    Try to stay with me without the correct grammar
    It did not eat the paint or plastic or anything
    It also did not even touch the stains not a thing I cannot believe that there is nothing out there that can take these stains off the paint
    I ordered some heavy duty clay that I am going to give a shot
    Also some 105 to cut the time it takes to cut
    I guess I am going to have to just work on putting clear bra over these areas
  10. #20
    Aug 2010
    Fairmont, MN
    75
    1,338
    22
    WOW!
    I'm really outa ideas. Ya think that it may NOT be tar? Can you feel it or does it lay flat? If you can feel it, possible you can scrap it off with your finger nail?
    From the pic you show, is that the only area that is affected?
    Bill
  1. Bad Water Spot Removal
    By snp1973 in forum Detailing 101
    Last Post: Aug 31st, 2014, 09:09 AM
  2. White road paint removal from carf paint
    By Show 'N' Shine Car Detailing in forum Detailing 101
    Last Post: Nov 18th, 2013, 11:49 AM
  3. Water Spot removal
    By dude808 in forum Detailing 101
    Last Post: Mar 10th, 2009, 07:39 AM
  4. spot scratch removal
    By tomee in forum Show Off Your Latest Detail Work
    Last Post: Mar 19th, 2006, 04:44 PM
  5. Water Spot Removal
    By 305Cummins in forum Detailing 101
    Last Post: Jun 27th, 2005, 05:52 PM
