M100 vs M101 vs M105? cutting old single stage opaque D151 questions
Results 1 to 9 of 9
Thread: M100 vs M101 vs M105? cutting old single stage opaque D151 questions
  1. #1
    Datsunscott
    Join Date
    Jul 2008
    Location
    Fountain Valley, CA 92708
    Posts
    12
    Rep Power
    11
    I am working on 1985 single stage opaque enamel paint on a huge extended van with a gelcoat fiberglass giant top.
    Its so bad I want to know difference between M100 M101 and M105. also wondering about M85.
    (Looking at paint safe polishing before other work/paint).
    I have some 105 and 205 here but havent tried the others.
    Any advice?
  2. #2
    Datsunscott
    Join Date
    Jul 2008
    Location
    Posts
    12
    Rep Power
    11
    Re: M100 vs M101 vs M105? cutting old single stage opaque D151 questions
    Ps Im using a da and foam pads, everything is drying fast in this hot weather
  3. #3
    Kinder Car Care Daniel Kinder's Avatar
    Join Date
    Dec 2006
    Location
    Paintsville Kentucky
    Posts
    1,253
    Rep Power
    32
    Quote Originally Posted by Datsunscott View Post
    Any advice?
    click on link below for video of what your needing to know about M100 M101 M105
    https://youtu.be/Ugl35QexkkQ
  4. #4
    Join Date
    Dec 2006
    Location
    Posts
    1,253
    Rep Power
    32
    Hey Datsunscott
    I know every paint is different and has different outcomes with different pads, products, speed of machine, pressure being applied, work area and so forth. With that being said, have you got and tried Meguiars Paint Recondition Cream?(Absolutely Love This Stuff!) I just polished a 92 GMC Single Stage Red Paint (just posted up, but not the greatest post>forgot how to size pics>sorry) using Meguiars micro fiber cutting pad (clean with compressed air after ever section your working on>Example: I break hood into 4 sections, unless its hard clear then into 6) Working clean as you know is Very Important and even more so on neglected Single Stage Paint.
    Preformed a test-spot first and found that the paint responded very well with my Rupes mkll 15 & again my Meguiars 5'' micro-fiber cutting pad on speed 4 1/2 with about 12-15 lbs pressure and making 3 slow section passes with more so then usually amount of product but on hood did have to do a 2nd step polish with a Harbor Frieght DA, polishing pad with M205 on speed 4 and with just 2 section passes with no more then about 10 lbs pressure using moderate arm speed. Didn't wipe off after each section (under canopy temp around 80's medium humity) and when did my 4 sections I then sprayed my foam polishing pad with Last Touch and used speed 3 weight of machine and sorta fast arm speed and did a horizontal pass over entire hood just to blend in. Hood was pretty bad shape, I was afraid of a burn through but luckily didn't happen.
    hope Ive helped or give some ideals to help out, don't forget that sometimes just because we've preformed a test spot that we can run into a section (hood, roof, trunk lid) that needs a different approach and technique and in some? occasions I've found that using more product on a freshly cleaned pad, slow arm speed and only 2 passes as worked for me.
    Also, if you haven't got a nano skin clay towel I highly recommend getting both, saves time and I use for everything especially cleaning headlights before I polish or wet sand on them. You wouldn't believe how much better the look after, plus saves your sand paper and/or pads from gumming up from contaminates.
  5. #5
    Datsunscott
    Join Date
    Jul 2008
    Location
    Posts
    12
    Rep Power
    11
    Thanks for the info!I do have some D151 paint cream and really like it too.
    Would use it but found out it is not paintable/paint safe.
    And thanks for the link- it was no longer in the meguiars thread I was reading.
    I am polishing the van and gelcoat roof before doing some paint repairs and caulking around windows.
    I want it all polished before some stripe respray and clearcoating the stripes.
  6. #6
    Registered Member
    Join Date
    Aug 2010
    Location
    Memphis, TN ~ USA 1
    Posts
    458
    Rep Power
    13
    Any advice?
    Polishing oxidized gel coat using 105 on a hot day is about as miserable as working conditions can get. You might try to spritz the pad with water (very little) to give yourself more working time.
    You are truly paying your dues working on this dog. Good luck
  7. #7
    Join Date
    Jan 2007
    Location
    Rochester Hills, Michigan
    Posts
    546
    Rep Power
    18
    M100 has more lubricants, but like M105, is LOADED with abrasives that you will get some dust.
  8. #8
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,017
    Rep Power
    80
    Just wanted to clarify, you are working on paint, correct? The gel coat/fiberglass is just the substrate, correct?
    With that said,
    If you are looking to get the best results, on this project, which requires a paintable product, our M100 Pro Speed Compound should be much easier to work with. Follow with our M205 Ultra Finishing Polish and you should be in great shape.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  9. #9
    Registered Member Alfisti's Avatar
    Join Date
    Jul 2004
    Location
    Perth, Western Australia
    Posts
    450
    Rep Power
    19
    Just to concur with the above comments. I have and use all three compounds. All excellent with different workflows and results on different paint and weather conditions.
    I would also recommend M100 in your situation. M100 is a lot 'wetter' having more lubricants than the other two. I find it works much better and longer on older dry paint, especially single stage, which becomes quite porous with age and tends to **** all the lubricant out of the compound.
    Paul Marmarinos
Thread Information
Users Browsing this Thread
Similar Threads
  1. Situation with D300, M105, M101, & M85 (Two Questions)
    By DRaider90 in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Aug 27th, 2016, 06:00 PM
  2. M101 VS M105 questions
    By torque in forum Professional Line - Product Reviews
    Last Post: Dec 9th, 2014, 10:56 AM
  3. Questions about Meguiar's M105, M101 and M100 Compounds? Watch this video!
    By Mike Phillips in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Mar 31st, 2014, 12:09 PM
  4. Volvo S60 - D151 Single Stage Detail
    By FinalTouchDetail in forum Show Off Your Latest Detail Work
    Last Post: Feb 23rd, 2011, 07:27 PM
  5. M105/M205 and single stage paint
    By ItalianM87 in forum Detailing 101
    Last Post: May 24th, 2009, 01:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
