Here I go again I guess no one wants to answer my other 2 questions, so this question is, on factory paint on a new toyota, would like 1500 or 2000 grit be to abrasive to start with, I want to wet sand a repaired scratch and then wet sand around the repair , so there's going to be some factory paint that I will be wet sanding also.
2000 or 3000 grit wet sanding,m?
Re: 2000 or 3000 grit wet sanding,m?
Hi Indiglofish61,
I know you have probably heard the phrase before, but especially when it comes to factory paint, and especially when sanding, we recommend using " the least aggressive method" needed. In general, yes, 1500 or 2000 hand sanding is a bit aggressive. We would recommend starting with a quality 3000 grit foam finishing paper or disc.
Originally posted by Indiglofish61 View PostI want to wet sand a repaired scratch and then wet sand around the repair , so there's going to be some factory paint that I will be wet sanding also.
Thanks and hope this helps.
NickNick Winn
