Ultimate Compound by hand for light spiderweb scratch removal?
Results 1 to 5 of 5
Thread: Ultimate Compound by hand for light spiderweb scratch removal?
    Aug 2015
    Owego, NY
    6
    5
    Hello, I have some light "spiderweb" and straight line scratches in my clear coat that is only visible under a light source and from an angle. I would like to remove these scratches. After a through washing and clay barring I applied Ultimate Compound by hand with a Meguiars foam applicator (the type that comes with their Ultimate Wax package) and despite using moderate uniform pressure it really didn't seem to remove any of the scratches.
    Is this to be expected while trying to do paint correction/compounding by hand, or am I possibly doing something wrong? Perhaps a more aggressive cutting pad applied by hand would work better? Or should I just look into getting a DA polisher and apply with the machine? Just looking for any advice, other experience others have had. Thanks, Kevin
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,398
    61
    Re: Ultimate Compound by hand for light spiderweb scratch removal?
    You are experiencing the limitations of doing things by hand. A DA will get you much better results.
    B.C.
    22
    15
    While a DA will certainly do more and take much less time, it helps to use the right application method. The foam applicator included with UW is an exceptionally soft foam, and will greatly diminish any product's cutting power. There's a reason why people don't use the black finishing pad on a DA to compound, and that holds true for working by hand.
    There's an entire sub-forum dedicated to hand-application, with a number of threads on scratch removal.
    Jul 2013
    Lawndale, CA
    40
    5,398
    61
    Here is a good video to watch when doing things by hand.
    Jan 2007
    Rochester Hills, Michigan
    570
    18
    You can amp up the cutting characteristic by switching to a microfiber or terrycloth covered applicator.
    Any haze could be cleaned up by going over it again with the foam.
  1. m205 or ultimate polish by hand for light swirls?
    By jkmhi89 in forum Working by Hand
    Last Post: Oct 13th, 2015, 08:44 AM
  2. Ultimate Compound vs Scratch X 2.0
    By derekstl in forum Detailing 101
    Last Post: Aug 30th, 2013, 05:47 AM
  3. Ultimate Compound by hand
    By Zach in forum Working by Hand
    Last Post: May 10th, 2011, 09:39 AM
  4. Using Ultimate Compound by hand
    By kimbo51 in forum Detailing 101
    Last Post: Apr 20th, 2010, 12:42 PM
  5. Scratch removed with Ultimate Compound...
    By Tuck91 in forum Show Off Your Latest Detail Work
    Last Post: Dec 10th, 2009, 07:29 AM
