Meguiar's Hybrid Ceramic Wax - Page 14
Page 14 of 25 FirstFirst ... 467891011121314151617181920212224 ... LastLast
Results 131 to 140 of 247
Thread: Meguiar's Hybrid Ceramic Wax
  1. #131
    Aug 2010
    Fairmont, MN
    77
    1,442
    24
    Re: Meguiar's Hybrid Ceramic Wax
    Thanx for the link Mike.
    Was kinda concerned when I saw the length (40min), but it was a good 40 min!
    Bill
  2. #132
    Aug 2010
    Fairmont, MN
    77
    1,442
    24
    Quote Originally Posted by Thomasfxlt View Post
    Good video. Answers a lot of obvious questions about the name of the product. I’ve been using HCW for 2 weeks now and have applied it to two different vehicles and it works. After you do the initial wipe-in, the spray on maintenance method is amazingly simple and vehicle drying is a fraction of the work. I like it.
    Looks like you will see how it works in snow this week (yuk - I still have a 5' drift in the back yard). Please come back and give a report on how it did.
    Bill
    Bill
  3. #133
    Mar 2019
    Brainerd MN
    6
    The rain yesterday helped but it looks like winter is not giving up it’s ghost just yet. I’m suppose to drive to Chicago on Thursday... ugh.
  4. #134
    Mar 2019
    Brainerd MN
    6
    So now I’m thinking about trying this as a semi-waterless detailer. I’d hate to use a something else on top of it so once you go HCW it seems you’re kind of committed. I’m thinking I’ll try misting the surface with plain water from a spray bottle and then use a damp cloth w small amount of product. Sort of the “drying aid” method but starting w dry car and then misting panel by panel. I think the key will be making sure the surface is cool/out of the sun. Obviously not something to do with a really dirty surface but as a quick touch up.
  5. #135
    Feb 2018
    San Diego, CA
    33
    3
    I'd be surprised if that works since it comes out so thick but let us know! I'm curious.
  6. #136
    Mar 2019
    Brainerd MN
    6
    Quote Originally Posted by parker23 View Post
    The trick is making sure the surface is damp and NOT spraying HCW directly onto the car. Apply a small amount to a damp towel then apply to a damp surface. Mist an area with water from a spray bottle then apply the HCW onto the damp towel and wipe/dry.
    I did this yesterday to my F150 and it works. Do it in the garage or shade. I did the entire vehicle with one drying towel and one microfiber applying towel.
    I wouldn’t waste a lot of time if the vehicle is really dirty but in a pinch to quick detail, it works and you’re going onto your previously HCW surface with HCW and not some other product.
  7. #137
    Apr 2019
    Washington, D.C.
    How long does Meguiars Hybrid Ceramic Wax last? Estimated? Is it similar to Meguiars Ultimate wax? I ask because I live in the mid-Atlantic and it's just too cold to wash and wax during the winter.
    Does Meguiars Hybrid Ceramic Wax have any UV properties? If not, what should I use on top?
  8. #138
    8,384
    94
    Quote Originally Posted by UMDHOOPS2002 View Post
    According to our R&D department, Hybrid Ceramic Wax can last up to a year. With that said, durability will be based on how the vehicle is stored & maintained. For example, a car that is not daily driven, stored indoors, wiped down with a detail spray everyday, was properly prepared, clayed, etc. is going to have much greater durability than a car that is driven daily, stored outdoors, washed monthly, was not properly prepared, etc.
    Please see above response, and also, yes, it protects against the sun. For best results we recommend using Hybrid Ceramic Wax in addition to your favorite liquid or paste wax.
    800-854-8073 ext 3845
  9. #139
    Oct 2017
    NJ
    7
    3
    As far as the first application goes, you spray it on when the car is still wet and you wipe it off with a microfiber. Do you rinse it again after this step? From what I understand, there are parts of the solution that need to be washed away to leave the protective layer?
  10. #140
    21,402
    1138
    Quote Originally Posted by sg11 View Post
    Here's what you should do for the very first application of HCW, especially if you don't have a really strong layer of protection on the paint to begin with.
    "Foundation Layer"
    1. Wash the vehicle with your normal process, rinse thoroughly but leave wet
    2. Spray no more than 2 trigger pulls of product onto a panel - 3 for a large panel such as the hood of a large vehicle, roof, etc.
    3. Dry with a quality microfiber drying towel
    4. Done
    If, on the other hand, you have really nice water beading from a previous, fresh wax application or you've already done the foundation layer as described above, then do this:
    "Standard Application"
    3. Rinse thoroughly with a strong stream of water. A pressure washer works great, but lacking same the best approach is to use a variable setting nozzle on your garden hose and select the flat fan spray pattern. Trust me here, it's the best choice of all the settings on the nozzle for this. We've tested more dang nozzles than I care to remember.
    4. Dry with a quality microfiber drying towel
    5. Done
    Now, if you're a regular here on MOL I'm guessing you're an enthusiast, or downright Car Crazy. Good for you. That means you might even want to do both of the above process in rapid succession. Yep, do the "foundation layer" process, then get the car wet and do the "standard application" process immediately. If you do this, especially on a non metallic black vehicle, you may see a very slight bit of streaking when you do the drying step of the foundation layer. Don't stress, don't fight it, don't do anything. Zip. Zilch. Nada. Just move on to the standard application process and you'll love the incredible slickness when you dry with a clean, dry towel. It's pretty crazy. And you'll see even tighter water beading immediately.
    There are basically two ways you can go wrong with this product:
    1. Over apply the product. Just go nuts spraying the car down with that lovely blue elixir. Lay it on super thick. You really want that protection!!!!
    STOP IT!!!
    That is NOT going to help you at all. In fact, it will make life much, much harder and you may end not liking a really awesome product! Why? Because you probably won't rinse off all of the carrier ingredients, which are actually highly hydrophillic - it loves water and will attract rather than repel it. So you end up with really lousy beading, and possibly a fair bit of streaking. True story - a friend of mine in Northern California applied HCW to his car and called me with this very complaint. I told him he probably overused the product. He admitted to using half the bottle on one car. I told him that was probably enough for 6 or 7 cars. He fell silent. He then asked how to fix it. I told him to wash the car with his regular car wash and everything would be fine, no need to even reapply the product. He said it was going to rain soon so he thought washing the car was a waste of time. I said "great!", let the car sit in the rain. That will wash off the last of the carrier ingredients, the beading will come up beautifully, and the streaking will be gone. He called me back that night and said it worked just as I said it would. Well, duh.
    2. Skip the foundation layer if the car has zero protection and water lays on the paint in a great big, non moving sheet. Just spray a little bit of HCW into that deep pool of water and rinse it off.
    STOP IT!!!
    That is NOT going to help you at all. A huge sheet of water on the paint won't let the active ingredients get to the paint. Those hydrophillic carrier ingredients will basically form a layer between the active ingredients and that huge sheet of water on the paint, so when you do rinse it off you rinse off everything. You leave nothing behind. If you have Lake Michigan sitting on your hood, partially dry it.... just move some of the water out of the way and expose a decent amount of paint. Don't dry it fully, just clear some of the water away. Now do the foundation layer process as described above, and then, because you're a MOL user, do the standard application as well. You'll thank me. Oh, but if water is doing a Lake Michigan impersonation on your hood, you've likely got some other issues.... like that paint may need to be clayed first, just as you normally would before applying a traditional wax or sealant. Do it.
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Pictures from Meguiar's May 20th, 2017 Saturday Detailing 101 Class with Team Hybrid
    By Nick Winn in forum Pictures from Meguiar's Training Garage -Detailing 101 Classes
    Last Post: May 25th, 2017, 06:09 PM
  2. wanted lc 5 hybrid pads
    By Topdawg57 in forum For Sale or Trade
    Last Post: Jul 10th, 2013, 05:54 PM
  3. Sierra, Camaro, Silverado Hybrid
    By Tuck91 in forum Show Off Your Latest Detail Work
    Last Post: Jun 7th, 2011, 02:42 PM
  4. Team Hybrid at Meguiar’s NXT Generation Garage *Press Day*
    By Mike Phillips in forum Pictures from Meguiar's Training Garage -Detailing 101 Classes
    Last Post: Feb 14th, 2004, 10:24 PM
