Meguiar's Hybrid Ceramic Spray Wax
  • Re: Meguiar's Hybrid Ceramic Wax
    Originally posted by BillE View Post
    With the introduction of more 'ceramic' products, especially M-27 and ceramic detailer...where and how does HCW play into the picture?
    TIA!
    Bill
    99 Grand Prix
    02 Camaro SS
      Thanx for the reply Michael.
      I should have been much more specific in my question...I am referring to Hybrid Ceramic Wax (G190526), the water activated blue spray (the one that smells like blueberry). It's my understanding that it is more of an LSP that 'touch-up' product (that's what I'm using it for and I DO LIKE it).
      Make sense?
      TIA again...
      Bill
        Hi,
        anyone tried of dilution of HCW with Meguiar x-press D15601? I was having the thought by combining that both will make the HCW less thick and easier to apply and at the same time having the properties of the slickness of D15601
          What type of durability are people seeing? I'm reading reports of "same as UFF" (which Im not familiar with) to "up to a year" to "better than ULW." Whats one to believe??
          2011 F150 5.0L 4x4
            In early summer last year I applied a Meguiar’s Hi-Tech ‘26’ yellow paste wax foundation on my 2019 Blade Silver C7 Corvette, followed a week later by a coating of Meguiar’s Hybrid Ceramic wax. For the remaining summer and early fall my Corvette probably received 2-3 more treatments of HCW before it was covered and went into unheated winter storage for the past 6 months here in Ontario, Canada. As we enter into the 2020 driving season I am considering applying a new foundation coat using Meguiar’s ‘Ultimate Liquid Wax’ followed by a coating of HCW, however I am curious as to Meguiar’s recommendations:
            - does a new foundation coating of ‘Ultimate Liquid Wax’ serve any benefits
            - seeing that my C7 already has HCW on its surface, any necessary steps needed prior to applying the ULW
            - is there a recommended number of HCW applications per season (I’m considering applying every 4-6 weeks).
            Helpful hint: Buy a standard 32 oz spray bottle, pour the HCW from the Meguiar’s bottle, add about 2 ounces of water into the Meguiar’s bottle, shake and pour into the 32 oz bottle, shake again. The two ounces of water will dilute the HCW just enough to the eliminate the ‘globing’ effect you may experience with the Meguiar’s spray bottle and the adjustable nozzle on the 32 oz bottle allows for finer droplets when spraying.
              Question, We have really hard water here in AZ so I usually have to go to the car wash and use the spot-free rinse option to try to keep spots to a min. Can I apply this using the lower spray pressure of the spot free rinse or does it require higher pressure? I thought I saw a post in here saying that one person sprayed their panel down to wet it then wiped this on using a towel that was moistend with the product and then dried afterward? Would that be a better optino for application?
                I would recommend spraying/spreading Hybrid Ceramic Spray Wax with the high pressure & then using the spot free for final rinse. I don't think the spot free is going to be strong enough. You can always "wax as you dry" but the "wax as your rinse" method is ideal after you have established a base coat. Check out the below link if you have not seen already:
                How to use Meguiar's NEW Hybrid Ceramic Wax!
                  Hello,
                  I've applied the HCW as per the instructions. HCW works as expected.
                  However, I wanted to know if any wax or polish can be applied on top of the HCW for added shine ?
                  Thanks
                    Originally posted by Nick Winn View Post
                    Hi imacarnut,
                    1. We do not claim UVA/UVB protection specifically. It does protect against the sun & provides a sacrificial barrier against elements of the environment, like our other waxes/sealants, but again we do not claim UVA/UVB specifically.
                    2. Yes it can build up. This is a good thing.
                    3. We have not been advised or noticed any special care required for towels used with Hybrid Ceramic Wax.
                    Hope this helps.
                    Hi Nick, I know you've answered this before but I wanted to ask you to go into a little more detail re: UV protection.
                    - Can I take #1 to mean that HCW protects against the visible spectrum and heat of the sun but not UV?
                    - If "no" to the above, which of your sealants do?
                    Thanks, my car is parked 24/7 outside with no shade so I gotta know.
                      Well, no product is going to prevent the car paint from getting hot...
                      But the general idea is to use the detailing products like polish and wax to keep the paint/clear coat protected and healthy. Then the paint will be able to use its UV inhibitors to keep itself safe.
                        Nick, (or anyone ��) all the directions I see advise spraying HCW on a wet car and using microfiber towel to dry (base) or spraying HCW and power rinsing off (on going) Is there a downside to using HCW on a dry, clean car? Or is the whole point simply for convenience? I tend to wash at the local hand held car wash but “wax” at home in the garage so using HCW dry is more convenient for me.
                        thanks
                        Ken
                          Well, I tried it... Washed the Jetta (white) as usual. It’s always WAY more dirty than I think it is... Brought it home and put a couple coats of HCW on, like I would a regular spray wax. Spray on, rub in, rub off with MF towels. No water or rinsing... Man that car is shiny! It’s 18 years old and I swear it’s never looked this good! I may try adding another coat at some point but hopefully this will make it through the winter. Great thread about a fantastic product. Thanks guys!
                            Hi,
                            Please advise, if I can use HCW spray instead of waxing , after Compounding (ultimate Compound) + Polishing (ultimate Polish).
                              Originally posted by Mandroid View Post
                              Hi,
                              You certainly can.
                              It is probably best to have a base coat of wax, then use the HCW. But if not practical, then you can use the HCW regularly instead.
                              Also, dont need the Ult Compound every time unless there is stuff to fix up.
                                Thanks for your Valuable advice
