Meguiar's Hybrid Ceramic Wax - Page 23
Page 23 of 25 FirstFirst ... 131516171819202122232425 LastLast
Results 221 to 230 of 245
Thread: Meguiar's Hybrid Ceramic Wax
  1. #221
    8,312
    94
    Re: Meguiar's Hybrid Ceramic Wax
    Quote Originally Posted by CRUZINBMW13 View Post
    would it be a bad idea to use show car glaze after adding the hybrid cermaic wax?
    Ideally it would be applied first. You would negate many of the benefits of using the HCW like extreme water beading & self cleaning effect. We are recommending for best results always use Hybrid Ceramic Wax as your final LSP "Last Step Product."
    800-854-8073 ext 3845
  2. #222
    Sep 2019
    Brampton, Ontario
    Bought a couple bottles this week, used for the first time last night. Black truck, tired of the streaks and watermarks, even with 100 layers of waxes/polishes. Went on nicely, first application so I did rub a bit, dry, of course, rain this morning. Did not see streaks before the rain, so, so far impressed.
    Couple of Q's if I may (searched, watched videos, didn't find an answer)
    a) Overspray/other surfaces- what about rubber trim, rims (painted or chrome or steel), decals, aluminum (painted though) bed covers... Hard NOT to hit those when spraying on, or rinsing off. What are the 'rules' for black trim mostly? Rims? Okay when oversprayed on to rubber tires?
    b) Boat surfaces, gelcoat specifically- I will test a spot first, wondering what the 'rules' are for sun faded white, or other, gelcoat?
    S
  3. #223
    Jul 2017
    Harpers Ferry, WV
    3
    I followed the directions and sprayed the HCW all over my 2015 Camaro and and my wife’s odyssey and had no issues. I did dry and buff everything except I didn’t use it on the engine bays. I like the product and find it very much like their x-press synthetic product. Wipes right off black trim. Even used it on my peel coat black exhaust tips. Again, no issues.
    1967 Buick GS 400. Triple Black Conv
  4. #224
    8,312
    94
    Quote Originally Posted by SeanO View Post
    S
    A) the product is primarily designed for use on paint but is safe for all exterior surfaces. No issue getting product on those surfaces, provided you are using correctly, do not let dry, etc. You can use it on wheels if you would like, especially if they are painted.
    B) The product has not been tested on non painted fiberglass / gel coat, but we imagine it will work fine, no likely going to work as well as it does on paint, but you are welcome to test like you mentioned.
  5. #225
    Registered Member snozan's Avatar
    Jul 2016
    Sweden
    43
    225
    6
    So i tried it, i don't know if this is for me. Was very hard to know if i got a fundation layer or not (i rinsed it down directly and put the traditional method right after). I used too much, however also here its very hard not to.
    Beside HCW i used "Sonax spray and seal", which costs half of what HCW does in Sweden. Similiar thing, and works very well
    I will be buying a bottle of Turtles "Turtle wax ICE seal and shine". Hoiwever its a spray wax but can be used a wet wax
    I honestly dont know if HCW is worth the money for me. $32 for a bottle that i used half of, isn't worth it when there is so much cheaper similiar products here - atleast i tried it
  6. #226
    Sep 2019
    Singapore
    Hi,
    I have ultimate fast finish, hybrid ceramic wax, and ultimate quick wax. I will like to seek advise on how to go about using them on my regular washes and maintenance.
    May I know if it needed to use all 3? Or can I just replace either one of them.
    Is overlapping of the products an overkill as its hide the true properties of the products apply.
    Which product should I layer first?
    i wanted to find the most efficient way use these products rather than just layering them on top of each other everytime.
  7. #227
    Oct 2019
    Elizabethtown,pa
    I detail our vehicles two times each year, once in the spring and early fall. This fall I gave the HCW a try on my '05 Dakota. Prior I foamed-hand washed it with Dawn dish detergent, hit it with clay bar then applied the HCW per the two step initial instructions only using a garden hose to rinse.
    After....
    Its not a garage kept, in fact its out in the elements 24-7-365. Two weeks later after have been driven in the rain a few times and not re-washed, me standing 25 feet away when taking this pic.
    So far so good!
    Bill
  8. #228
    39
    19,158
    237
    Most people would use something like the Fast Finish after their main detail.
    And then the HCW or the UQW would be after your regular wash.
    Yeah, a bit of overlap there.
    Honestly I am just using the UFF on the door jambs and stuff to use it up. But that could be a base layer. Or base layer + UQW.
    And then use the HCW with your regular washes.
    And make sure to follow the directions, its gets a bit smeary if you over use it, or dont rinse enough. But the smears go away...
  9. #229
    Dec 2015
    San Juan Capistrano CA
    658
    Quote Originally Posted by Billpa View Post
    Bill
    Bill
    You can use this procedure to move images into your Gallery on the Meguiar's Online Forums server.
    The procedure will tell how to add it to a post.
    https://meguiarsonline.com/forums/sh...ghlight=images
  10. #230
    Feb 2019
    San Diego, CA
    9
    Is it possible to use wax on the paint after accumulating layers of a HCW? I have a lot of Blackfire sealant and rather enjoy “wax on, wax off.” Can I ever wax again? Thank you.
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. Pictures from Meguiar's May 20th, 2017 Saturday Detailing 101 Class with Team Hybrid
    By Nick Winn in forum Pictures from Meguiar's Training Garage -Detailing 101 Classes
    Last Post: May 25th, 2017, 06:09 PM
  2. wanted lc 5 hybrid pads
    By Topdawg57 in forum For Sale or Trade
    Last Post: Jul 10th, 2013, 05:54 PM
  3. Sierra, Camaro, Silverado Hybrid
    By Tuck91 in forum Show Off Your Latest Detail Work
    Last Post: Jun 7th, 2011, 02:42 PM
  4. Team Hybrid at Meguiar’s NXT Generation Garage *Press Day*
    By Mike Phillips in forum Pictures from Meguiar's Training Garage -Detailing 101 Classes
    Last Post: Feb 14th, 2004, 10:24 PM
