Meguiar's 3 in 1 Wax - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 56
Thread: Meguiar's 3 in 1 Wax
  1. #21
    Nov 2018
    Westchester, NY
    Re: Meguiar's 3 in 1 Wax
    Hi & yes, middle of next month you will start to see items for sale online.
    Cool. Thank you very much.
  2. #22
    Feb 2008
    34
    12
    Is Color x discontinued ?
  3. #23
    Feb 2004
    Southeast Nebraska
    920
    27
    How does this compare to Mirror Bright Polishing Wax? Is the Mirror Bright line being discontinue?
  4. #24
    7,797
    88
    Quote Originally Posted by paoloporsche View Post
    ColorX is still around!
    Quote Originally Posted by tguil View Post
    Mirror Bright is not being discontinued. 3 in 1 vs MB Polishing Wax, 3 in 1 is a completely new ground up formulation, & is not based off of anything else. 3 in 1 will be more aggressive, better darkening ability (lots of polishing oils). I believe durability is similar. It's really everything we know about developing AIO / Cleaner Waxes, put into one, or 3 in 1. : )
    800-854-8073 ext 3845
  5. #25
    Apr 2013
    Minneapolis, MN
    22
    7
    2 quick questions while I wait to get my hands on it...
    1) What is the application of this like? Is it a product where you can apply it to the whole car then buff it out, or is it one where you should buff out each 2ftx2ft section as you go?
    2) I’m somebody who definitely appreciates keeping my car in good shape, but I would describe my interest as a few notches below a “professional” level. Is there any way you can compare this 3-in-1 to doing a separate polish and wax? I’m sure doing them separately will always reign supreme, but I’m trying to gauge if that would be worth the extra effort or if I will be happy with what the 3-in-1 gives me.
    Thanks!
  6. #26
    21,401
    1137
    Quote Originally Posted by Cranston37 View Post
    You can do it either way, actually. If you're pushing it, like with a cutting pad on a DA polisher, you may want to wipe off as you go to judge your level of defect removal. If you're just looking to give the car a nice freshening up then apply to the entire vehicle with an appropriate pad for what you're trying to accomplish and then come back and wipe off - done!
    Thanks!
    Cleaner waxes, including one with as much punch as this has, are not intended to replace a full multi step process. That said, if the paint is in serious need of defect removal then a multi step is really the only way to go to achieve a very high finish. But you might well be very pleasantly surprised at just how much correction you can get, with the right pad, if the paint is in only fair condition. I may get my wrist slapped for posting this, but while doing demos with this product at SEMA I put some on a microfiber cutting disc and removed 3000 grit sanding marks with it. Not as quickly as I would have with a dedicated compound, but it did it.
    If your aim is to machine polish a couple times a year to keep minor defects at bay, then 3-in-1 might be just the ticket for you.
  7. #27
    Apr 2013
    Minneapolis, MN
    22
    7
    Thanks, Michael!
    A follow up question to your post...
    Both these quotes bring up the same question - can you give some guidance on choosing DA pads, and even the machine’s speed settings, with the 3-in-1?
  8. #28
    21,401
    1137
    Thanks, Michael!
    You can dramatically alter the cutting power of 3-in-1 Wax (or any compound, polish, cleaner wax, etc) with pad choice and your technique with the tool. For example, if you treat this like a standard wax and apply it with a black foam finishing disc at speed 3 with quick arm speed, it's not really going to cut. It will add some polish to darken the paint and of course it will lay down some nice polymer protection, but it won't correct much of anything. On the far end of the spectrum, if you use it with a microfiber cutting disc and treat it like it's a compound (higher speed on the tool - maybe 5000 opm - and some pressure and slow arm movements over multiple passes) well, you can take out 3000 grit sanding marks.
    There's a lot in between those two scenarios, though. Foam cutting or polishing pads work great and, coupled with an appropriate tool speed, arm speed and number of passes they'll offer a broad range of cutting ability. Of course the paint is a huge variable here, so a test spot or two is always a good idea. Softer paints may correct very well with a foam polishing pad at 4500 opm or so, while harder paints may prefer a foam cutting pad. A test spot is always done to figure out what the paint likes, and to find the most efficient process to obtain the results you're looking for.
  9. #29
    Registered Member wht4drfa5's Avatar
    Jun 2010
    woodland hills, ca
    143
    I wanted to try and remove some light swirls on my 2017 Honda CRV, and I tried D166 and a black finishing and yellow polishing pad. I didn’t see the results I was hoping for. Do you think this product will cut a little more than D166? Or maybe another combo I could give a try using?
  10. #30
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    40
    5,422
    62
    Quote Originally Posted by wht4drfa5 View Post
    Try D166 on a polishing pad and see if that gets the results you are looking for. The finishing pad may not be enough to get the job done.
  1. Replies: 0
    Last Post: May 17th, 2018, 01:33 PM
  2. Meguiar's Newest 2011 TV Commercial - Meguiar's Promise
    By Mike Pennington in forum Company & Forum Announcements
    Last Post: Jun 17th, 2014, 03:07 PM
  3. Replies: 2
    Last Post: Dec 28th, 2009, 01:06 PM
  4. What's the difference between Meguiar's Super Micro Abrasives technology and Meguiar'
    By michaeld0983 in forum Hot Topics & Frequently Asked Questions
    Last Post: Jul 13th, 2009, 08:29 PM
  5. Replies: 2
    Last Post: Feb 27th, 2006, 08:05 AM
