Meguiar's D1801 Professional Wheel & Paint IRON DECON - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Meguiar's D1801 Professional Wheel & Paint IRON DECON
  1. #21
    Dec 2015
    San Juan Capistrano CA
    499
    8
    Re: Meguiar's D1801 Professional Wheel & Paint IRON DECON
    Thanks Nick for the feedback.
    PH scale goes from 0 to 14. Normally, we think of neutral as being 7.0. However, it is not wrong to have a range for that definition.
    Distilled water has a PH of 7.0, salt water 8.0, milk and saliva are about 6.3.
    So milk is the stuff in milk shakes that I readily put into my tummy.
    That saliva stuff is what the pretty girls used to leave on my cheek when she kissed it.
    OK, I can be pretty neutral on that.
    Thanks for the update, I did look for my slide rule in case we needed it. I think it must be stored in the same place as my youth.
  2. #22
    Aug 2010
    Fairmont, MN
    75
    1,407
    23
    Slide rule? EEEGH-that's how to make SOME folks really feel old! LOL!
    Bill
  3. #23
    Feb 2018
    San Diego, CA
    28
    Here are a couple pictures from an upcoming video we filmed on this product! The white car below went from a light due of yellow to a crazy bright white! It was really impressive! The audi wheels at the bottom started turning purple before I could even finish spraying the entire wheel down!
    Hi Nick - Is it safe to say this product removes all wax and sealant? Or is an IPA wipe down after second still recommended before applying sealant/wax? Thanks!!
  4. #24
    Feb 2018
    San Diego, CA
    28
    Anyone else know if products like this generally remove some or all wax/sealant?
  5. #25
    21,401
    1137
    Quote Originally Posted by parker23 View Post
    D1801 may compromise your existing wax to some extent, depending on whether it's a carnauba wax or a synthetic sealant, and how long ago it was applied (ie, how much is really still there). But since this product is generally used as part of a decontamination process prior to more extensive correction work, whether or not it will strip wax is usually not a major concern. Everything else you're going to be doing will take care of that!
    Now, if you're asking because you want to strip wax as part of a full decon process prior to machine polishing, then the answer remains the same - it will likely compromise the existing wax at the very least. Again, since you're going to be doing other steps (claying is likely still needed as this product primarily attacks ferrous contaminants) then you'll be pretty effectively killing off that remaining wax/sealant.
    If you happen to have a paint coating on the car, this will not knock it down.
  6. #26
    Feb 2018
    San Diego, CA
    28
    Thanks!!! Is it better to spray on dry paint and wheels or wet?
  7. #27
    May 2009
    Lynchburg, VA
    470
    15
    After our first couple of weeks in use, I'm convinced this product is on par with our previous iron (X) decontaminator, and priced better. Thanks for filling another spot in the detailing arsenal.
    parker, I'd add that in most cases you'll use this on a wet car, after all you want to wash most of the dirt and debris off before applying the Iron Decon. Where I wouldn't dry the car before applying, it is beneficial to spray it on a surface that has drained itself of MOST of the rinse water after washing. If you apply it while the car is still flooding water off the surface you're likely to wash away a good portion of your Iron Decon. If you apply it to a bone dry area, just make sure that you don't allow the Iron Decon to dry while you're waiting for it to do its job.
    So my answer is YES and NO.
  8. #28
    7,354
    83
    I would agree with HCAD's recommendation below, regarding whether to use on dry or wet paint.
    Quote Originally Posted by HCAD View Post
    Happy to hear!
    800-854-8073 ext 3845
  9. #29
    I like shiny xantonin's Avatar
    May 2009
    Phoenix, Arizona
    31
    715
    107
    This may not be a fair comparison, but I am curious on the differences - how does this compare to Ultimate All Wheel Cleaner?
  10. #30
    Jan 2019
    Melbourne Australia
    6
    Quote Originally Posted by xantonin View Post
    I'd like to know this too. Both are iron decontaminators in a gel preparation.
  1. Ultimate All Wheel Cleaner stripped paint off my wheel.
    By NolanR in forum Customer Service Hotline
    Last Post: Aug 13th, 2018, 08:48 AM
  2. DUB Wheel Cleaner / Iron-X
    By Super Dave in forum Detailing 101
    Last Post: Sep 18th, 2015, 06:38 AM
  3. Meguiar's Professional ULTIMATE APC
    By KidDetailer in forum New Product Suggestions
    Last Post: Dec 12th, 2013, 01:09 AM
  4. Meguiar's on cast iron?
    By 100kdown in forum Detailing 101
    Last Post: May 31st, 2012, 11:32 AM
  5. 2001 BMW M3, Paint Decon and Correction
    By RaskyR1 in forum Show Off Your Latest Detail Work
    Last Post: Apr 8th, 2012, 06:59 PM
