Swirl marks after applying Ultimate Polish
Results 1 to 10 of 18
Thread: Swirl marks after applying Ultimate Polish
    Dec 2018
    Sylvania, OH
    Hello all,
    I’m new to car detailing.
    I have 6-month-old BMW black metallic color. Few days ago, I fixed a chip with applying matching paint and sanding. However, I got a dull spot after sanding which is expected. I applied Meguiar’s Ultimate Polish using Meguiar’s applicator pad, then I cleaned it with microfiber towel. Dull spot is gone, but I was surprised to see many new fine swirls in the area.
    Did I do something wrong?
    And how can I fix this by hand? Should I apply Ultimate compound?
    I don’t want to buy DA for such small area.
    Dec 2015
    San Juan Capistrano CA
    484
    8
    Re: Swirl marks after applying Ultimate Polish
    Possibly I can ask some questions that might help others help you.
    Can you tell us what sandpaper and grit you used to sand down the area?
    Did you use a hard or soft backed sanding block, or just fingers?
    Did you dry sand or wet sand?
    1,500 grit wet sanding marks will normally require a compound to remove the scratches and then polish to refine the finish.
    You may be able to wet sand with 3,000 grit (or higher) to reduce the effort needed for compounding.
    Dec 2015
    484
    8
    Here is a good article by Michael Stoops:
    The Power of 3000 Grit. https://meguiarsonline.com/forums/sh...r-of-3000-Grit
    Note that he mentions that hand sanding with 1500 can be more agressive than machine sanding.
    Don't worry when reading about not having a D/A, the ideas will still come across.
    Dec 2018
    Sylvania, OH
    I used 3M 3,000 grit (which is very soft). I wet sanded.
    I used my fingers to wet sand a small area around 1x1 inch, then polished a larger area around 5x5 inch. Swirl marks appeared in the whole 5x5 inch area.
    Dec 2015
    484
    8
    Here is another thread on M105 by hand vs 2500 grit wetsanding marks
    https://meguiarsonline.com/forums/sh...tsanding-marks
    Also can you describe how you cleaned the area before and after sanding?
    It is important to keep the sanding residue from getting caught in your hand polishing pad and inflicting scratches.
    Dec 2018
    Sylvania, OH
    It is important to keep the sanding residue from getting caught in your hand polishing pad.
    Before sanding, I cleaned with alcohol, clay bar, then soap with water. I did soap with water after sanding and before polishing.
    Dec 2018
    Sylvania, OH
    What should I do now to remove these swirl marks?
    I read that I can do UC then UP. Are these easy to apply by hand on an area with 5x5 inch?
    Dec 2015
    484
    8
    Do you have an image you can post?
    If you have trouble, send me a PM.
    Old Bear
    Dec 2018
    Sylvania, OH
    Old Bear
    Here it is:
    I already bought UC but I have not opened it yet. Is it worth trying?
    Dec 2015
    484
    8
    Here is the best thread that I find for uploading images.
    Thanks RoushStage2
    How to upload and insert an image into your posts
    https://meguiarsonline.com/forums/showthread.php?24941-How-to-upload-and-insert-an-image-into-your-posts
  1. Minor Swirl Marks after Sanding/Compound/Polish/Wax
    By locorecto in forum Detailing 101
    Last Post: Aug 23rd, 2018, 08:34 AM
  2. Replies: 8
    Last Post: Sep 18th, 2016, 08:50 AM
  3. Replies: 19
    Last Post: Apr 17th, 2016, 06:29 PM
  4. Would Polish or Wax helps remove swirl marks?
    By gar_lei in forum Detailing 101
    Last Post: Aug 31st, 2009, 08:30 AM
  5. Question about swirl marks and polish
    By Mura2005 in forum Detailing 101
    Last Post: Oct 29th, 2005, 09:11 PM
