Wet sand bonnet (hood)
Results 1 to 10 of 17
Thread: Wet sand bonnet (hood)
    Oct 2017
    Na
    16
    Would like to do some wet sanding on the bonnet hood area this has been resprayed from previous ower by the looks of it..
    I can see a few dirt nibs would liked removed
    Also would like to reduce the OP just knock down the high spots of it..
    Been doing PTG readings and getting 98 micons near some of the edges the rest of areas im getting from 115 to 170 microns
    Could i use a p2000 Finishing disc and perhaps and interface pad as well would it be safe to do the job?
    Would the finishing disc be less aggressive then sanding by hand?
    Could i just use the p2000 disc then compund or would i have to go p2000 then 3000 then compund?
    Dec 2015
    San Juan Capistrano CA
    451
    8
    Re: Wet sand bonnet (hood)
    Here is a good article by Michael Stoops:
    The Power of 3000 Grit. https://meguiarsonline.com/forums/sh...r-of-3000-Grit
    Note that he mentions that hand sanding with 1500 can be more agressive than machine sanding.
    Oct 2017
    Na
    16
    No worries thanks old bear
    21,386
    1136
    If the panel has been resprayed and you're getting the PTG readings you are, it sounds like you've got a decent amount of paint on the panel. If it is in fact a respray then it sounds like it was a bare metal spray as those numbers aren't too far off what we'd expect to see from an OEM finish. What's perhaps a bit worrying here is that there could have been some isolated damage that required a full fix in a small spot where the color was blended, and then the entire panel was scuffed and fresh clear shot over it (you can't really blend clear, so this is a fairly standard practice).
    That said, 2000 grit on a DA sander, with an interface pad, isn't going to be terribly aggressive and, depending on the paint hardness, those 2000 grit marks should buff out pretty easily. I'm always a fan of refining the sanding marks as much as possible to make the buff out less invasive (ie, less chance of overheating the paint due to aggressive machine compounding). Orange peel reduction may be pushing it with that paint thickness, but if the texture is more of a dry spray or similar fine texture issue, then the process you describe might just be the ticket.
    The following was taken from an article dating back to our NXT Institute training session in 2014 Note that we started with even less paint than you have (roughly 90 microns) and we only used 3000 grit on a DA before polishing. This was also a respray, and a bad one at that. It's amazing the changes you can make to the appearance with very minimal paint removal.
    How's this for a little non invasive paint correction: this is on a rental BMW with a truly horrid respray on the rear of the vehicle. The paint had an incredible amount of texture and therefore almost zero clarity in the reflections (if you want to call it a reflection!). Two things to observe in the images below: A) the paint thickness readings showing the minimal amount of paint removed, in this case 0.05 mil which is virtually nothing, and B) the clarity of the reflection of the paint thickness gauge in the "after" shot on the right versus the "before" shot on the left. This level of correction was achieved with a 3000 grit finishing disc on a DA followed by M205 on a microfiber cutting pad. Yes, you read that right - M205 on a microfiber cutting pad.
    A "before" reflection on the same hood.
    An "after" reflection on the same hood, after using the steps described above.
    This may not be Facebook, but this is indeed a selfie, shot in the "before" of that horribly resprayed hood. How's that for texture and lack of clarity?
    Same hood, same process as above. How crazy is that?
    Oct 2017
    Na
    16
    Yes im always amazed what 3000 grit can achieve.
    So if i use the 3m 3000grit sanding disc i should be safe with the ptg readings im getting?
    What speed setting do you recommend on the da?
    Dec 2015
    451
    8
    To help others answer your question, are you referring to the 3M Trizact foam sanding disc 3000 grit.
    The foam will help follow the paint texture contour, rather than remove it, like one of the non padded disc might do.
    https://www.detailing.com/store/3m-0...-in-p3000.html
    Oct 2017
    Na
    16
    So use a trizact 3000 non padded disc then?
    Oct 2017
    Na
    16
    Mike that post you were referring to were u using a megulars 3000 finished disc?
    So should i use a non padded disc and no interface pad or will using an interface pad be ok?
    21,386
    1136
    Quote Originally Posted by xrmte View Post
    We used a 3000 grit finishing disc (built in thin foam) and an interface pad. We normally recommend use of the interface when doing paint correction rather than texture leveling, but if your plan is to level texture then you'd want to skip the interface pad. Just be very, very aware of any contours, great or small, when doing so. Especially if you have no prior experience!! Wet sanding, when done right, can be very non-invasive to the paint due to the lack of heat from heavy compounding. But it can also bite you pretty quickly if you're not paying attention.
    As for speed settings on the DA, stick with roughly 3 to 4 on the speed dial, depending on the tool. You want pad rotation, but it doesn't have to be spinning really fast. In fact, too much pad spin and too much water can cause you to hydroplane and lose cut. If you do lose spin you'll still cut because it's sandpaper, so pad rotation isn't quite as critical as when polishing paint. Just use the weight of the tool and let the abrasive do it's job. Oh, and 3M Trizact etc are really more of a damp sanding process - no need to soak the discs in water first, and no need to flood the surface with water. A couple trigger pulls of a spray bottle, both onto the paint and onto the abrasive disc is all that's needed. As you see residue start to build on the disc, clean it thoroughly by spraying water on it. This is critical to avoid pigtails.
    Oct 2017
    Na
    16
    Thanks mike great information
    I would like to reduce the op texture so as you said use the 3000 finishing disc without the interface pad
    Do you know many mils could be removed when just using the finishing disc straight on the backing plate?
    What would be a safe PTG range reading to use these discs to reduce op where is the limit?
  1. replacing bonnet or using the same bonnet
    By kaikohe808 in forum Detailing 101
    Last Post: Aug 12th, 2014, 07:43 PM
  2. 1959 Impala: Hood and Trunk color sand
    By Ojai in forum Show Off Your Latest Detail Work
    Last Post: Apr 6th, 2011, 04:53 PM
  3. Wet sand audi hood
    By jaken1913 in forum Detailing 101
    Last Post: May 27th, 2010, 01:19 PM
  4. GC MF Bonnet vs. Ultimate Bonnet
    By Magic in forum Detailing 101
    Last Post: Jan 24th, 2006, 01:42 PM
  5. Replies: 6
    Last Post: Jun 21st, 2005, 05:31 AM
