Question about adhesive left on car
Results 1 to 10 of 10
Thread: Question about adhesive left on car
    Dec 2018
    Hurricane UT
    Hello all,
    I have some adhesive (I think) left on my truck hood. This was holding down a bug deflector so it was 2 sided tape. On the left in the pictures is about as good as I can get the adhesive removed. On the right, I haven't even started yet.
    My process is heating the adhesive with a hair dryer (it was 40 degrees outside today, but I parked the black truck directly in the sun, and the hood was getting hot), then I tried WD40. After that didn't work, I heated it up again, then tried goo gone and a plastic razor blade scraper.
    On the left now, when I run the plastic razor blade over it, it feels like there is nothing there. However when I run my thumb over it, it feels a little "sticky" or "uneven". I'm worried the paint has been damaged from the tape.
    Can you guys think of anything else I can do to get all of this to come off, or repair the issue if the paint has been damaged, without repainting?
    -Pat
    Aug 2010
    Fairmont, MN
    75
    1,377
    22
    Re: Question about adhesive left on car
    First off...Welcome to MOL!
    When I've had to deal with 'sticky stuff' I start with the most gentle solvent I have and dab at one SMALL area with a "Q-Tip." By gentle I am referring something like rubbing alcohol then stepping up to hotter stuff.
    Make sense?
    Bill
    Dec 2018
    Hurricane UT
    Yes it does. What would be hotter stuff than WD40 or Goo Gone?
    -Pat
    Apr 2007
    US
    1,070
    22
    I have used varsol (household paint thinner) to remove road tar. It might work on the glue, doesn't hurt the clearcoat, and wax the area after you are finished.
    Aug 2010
    Fairmont, MN
    75
    1,377
    22
    Quote Originally Posted by pfeinauer View Post
    -Pat
    Think along the lines of (in no particular order): denatured alcohol>paint thinner>kerosene>lacquer thinner>acetone>commercial adhesive remover. Ya wanna find something that will soften the glue so you can GENTLY scrape it off ( soft popsicle stick works good). This is why I say using a Q-Tip to see what will work. Even give a strong household cleaner a shot. Just keep rubbing the surface to a minimum-you don't want to install any unnecessary marring.
    My thoughts: Don't be in a hurry to get that stuff off, just take your time. I know it can be frustrating, just keep at it.
    Bill
    Sep 2008
    west branch, michigan
    76
    hoppes #9 gun cleaner has worked for me with a heat gun didnt work
    Aug 2010
    Fairmont, MN
    75
    1,377
    22
    #9! Who whoulda thunk it?
    Thanx for the insight...
    Bill
    Jun 2014
    Sault Ste Marie Ontario Canada
    55
    5
    be sure to let the wd40 or goo gone to sit for up to 5 minutes to allow it to work. if you spay and wipe it does not give the product time to work. Good luck
    Feb 2004
    Southeast Nebraska
    916
    26
    3M Adhesive Remover https://www.3m.com/3M/en_US/company-...3194120&rt=rud Also available in quart cans. Great for road tar removal too. Be sure to follow directions. Been using the stuff for years.
    May 2009
    Lynchburg, VA
    455
    14
    Quickest method is an eraser wheel attached to a drill. More commonly used to remove pinstripes, it'll pull the adhesive right off the paint. There are plenty of video examples on YouTube to give you an idea. Some light polishing on the paint will likely be necessary after you've removed the gunk.
  1. tape adhesive
    By KidDetailer in forum Detailing 101
    Last Post: Jul 25th, 2013, 11:11 AM
  2. Removing left over adhesive
    By Damien254 in forum Detailing 101
    Last Post: Apr 11th, 2006, 12:15 PM
  3. Wax/Adhesive Remover
    By Pete-FWA in forum New Product Suggestions
    Last Post: Jan 9th, 2006, 03:47 AM
  4. Adhesive Removal
    By RamAirV1 in forum Detailing 101
    Last Post: Sep 13th, 2004, 02:26 AM
  5. NXT looks so good and carefree, I'm left with nothing left to do but drive!
    By Alexandra in forum Meguiar's Consumer Line Products
    Last Post: Feb 14th, 2004, 05:36 PM
