NXT Prep
  • NXT Prep
    I have a 98 Mark VIII that the paint is in great condition. When I bought it this past October the guy I got it from said he had put Zanio on it. I used some good quality wax on it to keep it protected over the winter now I have the NXT and I want to do it the right way to make it look the best. What is the best step by step method? Here is a picture of it now.
    Thanks,
    Tom
    98 MarkVIII LSC
    04 Honda Pilot
    00 Harley Softail
    "Son, you're gonna drive me to drinkin' if you don't stop drivin' that Hot Rod Lincoln."
    Charlie Ryan - 1955
    It looks like you have a good base to work from so i would use a good paint cleaner, deep crystal or #9 - #7 polish and then NXT. I have used just NXT and had great results.
      Re: NXT Prep
      Thanks,
      Tom
      Hi BigT
      Welcome to Meguiar's Online!
      If you want, apply to thin coats of the NXT Tech Wax right over whatever Zaino is still there. I have applied a lot of Tech Wax over a lot of Zaino lately and each time the results are dramatically better looking, especially in bright lights.
      If you want to do an extra cleaning step to insure all of the Zaino has been removed and the surface is perfectly clean, then you could use any of the below products by hand,
      ScratchX
      Deep Crystal Paint Cleaner
      Medallion Premium Paint Cleaner
      If you want to use a PC then I would recommend using #83 Dual Action Cleaner Polish
      Mike
