Removing left-over adhesive from window tint
Results 1 to 5 of 5
Thread: Removing left-over adhesive from window tint
    Oct 2017
    Texas
    67
    3
    Hello to all
    I removed the old window tint on my car and was wondering if there is something more effective besides basic soap and water along with using a blade to remove the residual adhesive left on the glass.
    Also is it safe to use a plastic blade on the rear glass which has the defrost system? If not what can i use in addition to microfiber towels?
    Regards,
    mark
    Jun 2014
    Sault Ste Marie Ontario Canada
    82
    7
    Re: Removing left-over adhesive from window tint
    use a foaming glass cleaner. lots and a new razor blade. hold blade on a angle and flick off eccess foam and glue. Once you get the hang of it no problem. Good Luck
    Oct 2017
    Texas
    67
    3
    Cool Re: Removing left-over adhesive from window tint
    Greetings to all
    can i use a plastic razor blade on the rear glass? Is it safe on the defrost system? If not recommended, what can i use besides towels to scrub off the residual adhesive?
    Regards,
    Mark
    Jun 2014
    82
    7
    If the defrost has the wires on the outside of the glass no you cannot scrape with a plastic razor blade or you will cut the tiny wires and they will not work. Sorry
    May 2019
    Montreal, QC & Redding, CT
    5
    Quote Originally Posted by se9303 View Post
    Hello to all
    Regards,
    mark
    Buy a clothing steamer! You absolutely have to use that to remove window tints. It is by far the easiest way to remove window tints. If you don't leave the steamer in particular area for long enough before removing the tints, some if the adhesive will be left behind. It happened when I took off my tints last year. All I had to do was use the steamer to reheat the adhesive and it came off easily. Be careful with the rear glass with the defrost system but mine tint came off completely and rear defrost still works perfectly.
  1. Question about adhesive left on car
    By pfeinauer in forum Detailing 101
    Last Post: Dec 9th, 2018, 08:22 AM
  2. window tint law help...
    By SX4DUDE2013 in forum The Break Room
    Last Post: Jan 23rd, 2011, 10:26 PM
  3. Anybody do window tint???
    By RickyMartinZ28 in forum The Break Room
    Last Post: Apr 16th, 2009, 07:34 AM
  4. Removing left over adhesive
    By Damien254 in forum Detailing 101
    Last Post: Apr 11th, 2006, 12:15 PM
  5. Removing window tint
    By Andy M. in forum Detailing 101
    Last Post: Dec 27th, 2004, 04:05 PM
