Rookie Mistake: Meguiar's
Results 1 to 10 of 13
Thread: Rookie Mistake: Meguiar's
    Jul 2008
    Maryland
    6
    Please help! I was using a microfiber towel with Quick Detailer on the exterior of my car when washing it. I forgot to switch the towel to a new one when I started working on the interior of my car. I used the same towel with the Quick Detailer on a couple of shiny plastic dash components and the HVAC knobs. I thought everything was fine but noticed when the product dried it sort of bonded to the plastic and I can see where i wiped.
    I tried to get it off but it had already dried. Is the plastic ruined or will the product eventually wear off?
    Thanks!
    Jun 2014
    Sault Ste Marie Ontario Canada
    64
    5
    Re: Rookie Mistake: Meguiar's
    Try soap and water. If that does not work use some quick detailer on a cloth to activate the dried Detailer and then use soap and water to wash the area. Good Luck
    Jul 2008
    Maryland
    6
    Quote Originally Posted by Sleper View Post
    Thank you for the reply. I failed to mention that this was Exterior Quick Detailer in the black bottle. I'm concerned it has somehow bonded to the softer interior plastic. Think I should still try the method you suggested above? If so, what kind of soap?
    Jun 2014
    64
    5
    Yes the exterior detailer should not harm the inside plastic. Sounds to me like it just dried prior to it being removed
    Jul 2008
    Maryland
    6
    I'll give it a try. What kind of soap should I use? Dish soap?
    Jun 2014
    64
    5
    yes Dawn works well
    Jul 2008
    Maryland
    6
    Thumbs up Re: Rookie Mistake: Meguiar's
    yes Dawn works well
    Last night I tried both using just soap and water and the Exterior Quick Detailer with Soap and Water. Unfortunately, this had little to no effect that I can see.
    I went pretty light on the soap/water mixture. What ratio should I use and is there anything else I could try.
    Thank you for all your help on this.
    Jun 2014
    64
    5
    get a rag wet with detailing solutuon and hold on affected area for a minute or so and it should turn the residue back into a liquid and it will wipe off. The mixture does not need to be strong to soap and water just a little omore than you would use to do dishes. good luck
    Jul 2008
    Maryland
    6
    Wanted to give you an update. So I tried applying a wet microfiber towel of the Quick Detailer Product for a minute or so. Nothing came off
    Any possibility this will wear off naturally over time?
    Jun 2014
    64
    5
    Yes I would wait, you want to be careful as not to use anything too strong as it could permanently damage the interior components
  1. Replies: 1
    Last Post: Nov 18th, 2016, 09:48 AM
  2. Replies: 0
    Last Post: Apr 23rd, 2016, 07:18 PM
  3. Replies: 0
    Last Post: Apr 23rd, 2016, 07:02 PM
  4. Rookie Mistake, sprayed Ultimate Protectant on car by mistake
    By lancergts2011 in forum Detailing 101
    Last Post: Jun 1st, 2011, 06:05 PM
  5. Replies: 3
    Last Post: Apr 2nd, 2009, 10:51 PM
