Which products do NOT stain plastic and rubber
  • Which products do NOT stain plastic and rubber
    So i've used the Ultimate serie for a long time. Only reason i used them is because they didnt stain black trim (rubber and plastic)
    Question is, is there anything out there, or is the Ultimate serie "Unique" in that aspect? Can't be bothered with tape everything off, i want to go directly into all the fun.
    Re: Which products do NOT stain plastic and rubber
    Ult LIQUID Wax is my 'go to' for plastic 'stuff'. I kinda gave up trying what may or may not stain, so hence, just stick with it.
    Bill
      Bill
      Hmm, what i thought then. I use everything in "ultimate serie" Compound, polish and wax - just because it dosent require alot of extra work. The bottles are soon empty so i thought i would check if there is something out there. I guess the new "3 in 1" stain plastic? Would have been awsome if it didn't
        From the initial write up (when it was introduced) it did say, "...may stain plastic and rubber." I realize that 'may' means a 'possibility', from just that I don't think I'd chance it.
        Bill
          Not sure about the staining but I'd advise against using polish on trim - you'll knock down the grain and change gloss level. Maybe even make it patchy.
            Never had any issue with that I use Concept vista for plastic trim https://www.conceptchemicals.com/products/vista
              I have not had an issue with Meguiars Ultimate Liquid Wax staining trim.
              IIRC The Paste version Megs Ultimate Paste Wax may/can stain trim.
              Merlin - A Miracle Detailing
              YouTube - Facebook - - Instagram
                You have to first determined what purpose you use this . Then you can research in market which will be best to use as far concerns.
