G110V2 or G220V2 - Questions on Cruise Control and other feature
Results 1 to 3 of 3
Thread: G110V2 or G220V2 - Questions on Cruise Control and other feature
  1. #1
    Registered Member
    Join Date
    May 2019
    Location
    mumbai
    Posts
    2
    Rep Power
    1
    Hello everyone,
    I am not sure this question has been brought up before but I am unable to find the answer I am looking for so I have to make a post to ask here.
    I have watch plenty of youtube videos and posts that demonstrate the cruise control feature of the Meguiar's DA Polisher G110V2 (or G220V2 for the place I am living at).
    Typical scene in the video is the user turns on the machine, it spins, then applies pressure on top, and the sound of the machine changes, which is claimed to be an indication of cruise control in action (I do not doubt that), and then pressure released, the sound of the machine changes again to the state like the beginning.
    Posts explaining the cruise control feature typically just telling the readers that there is a circuit in the machine, once it senses the pad rotation is about to bog down, it feeds more torque to the motor in an attempt to keep the pad rotating. It does not explain what means the circuit uses to sense the pad is about to bog down though (I do not blame that since this is more like electrical/electronic discussion). There is also no explanation on how far the cruise control can help at each speed setting used by the user.
    So I have to make assumption here.
    I am assuming the cruise control will automatically increases the speed setting when it is triggered on to a higher speed setting than the one the user is currently using. For example, if I was running at speed 3 on the dial, I press on the pad till it almost bog down, then the cruise control increase it to 4, maybe even 5 or 6 if bog down still continue to be sensed by the circuit.
    Thank you!
  2. #2
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    7,358
    Rep Power
    83
    Re: G110V2 or G220V2 - Questions on Cruise Control and other feature
    Hello,
    When you apply pressure on the machine, you are slowing down the OPM's from the pressure itself. The machine and "cruise control feature" then works to keep the OPM's at the selected speed setting, not above it. The machine will not go above the selected speed setting due to an increase in pressure.
    Hope this helps.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  3. #3
    Registered Member
    Join Date
    May 2019
    Location
    mumbai
    Posts
    2
    Rep Power
    1
    Quote Originally Posted by hardus77 View Post
    Hello everyone,
    Thank you!
    Thank you
Thread Information
Users Browsing this Thread
Similar Threads
  1. G220V2 or G110V2 - Replacement wrench and carbon brushes
    By scoutfai in forum Machines - The Dual Action Polisher
    Last Post: Mar 1st, 2019, 12:55 PM
  2. G110V2 or G220V2 - Questions on Cruise Control and other feature
    Last Post: Jan 29th, 2014, 05:23 PM
  3. Replies: 20
    Last Post: Jul 31st, 2012, 06:09 AM
  4. G110v2 and G220v2
    By nothelle in forum Machines - The Dual Action Polisher
    Last Post: Jan 6th, 2012, 03:44 PM
  5. UK USER - G110v2?? G220v2??
    By mk2r32 in forum Machines - The Dual Action Polisher
    Last Post: Jun 13th, 2010, 10:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
